on 06-08-2022 13:55
hello need a engineer drop outs and one of my upload lines is sitting at 32qam BQM link down and top speed i get on upload is 10mbps been 48 hours now ive cleaned the fibre outside because thought there would be durt on it but only made the download we bit better and helped on errors
25 | 331000000 | -2.000000 | 38.983261 | QAM256 | 25 |
1 | 139000000 | 1.000000 | 40.366287 | QAM256 | 1 |
2 | 147000000 | 1.200001 | 40.366287 | QAM256 | 2 |
3 | 155000000 | 1.299999 | 40.366287 | QAM256 | 3 |
4 | 163000000 | 0.900002 | 40.366287 | QAM256 | 4 |
5 | 171000000 | 0.299999 | 40.366287 | QAM256 | 5 |
6 | 179000000 | 0.099998 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 0.200001 | 40.946209 | QAM256 | 7 |
8 | 195000000 | 0.200001 | 40.366287 | QAM256 | 8 |
9 | 203000000 | 0.000000 | 40.946209 | QAM256 | 9 |
10 | 211000000 | -0.099998 | 40.366287 | QAM256 | 10 |
11 | 219000000 | -0.400002 | 40.366287 | QAM256 | 11 |
12 | 227000000 | -0.299999 | 40.366287 | QAM256 | 12 |
13 | 235000000 | -0.299999 | 40.366287 | QAM256 | 13 |
14 | 243000000 | -0.099998 | 40.946209 | QAM256 | 14 |
15 | 251000000 | -0.299999 | 40.366287 | QAM256 | 15 |
16 | 259000000 | -0.500000 | 38.983261 | QAM256 | 16 |
17 | 267000000 | -0.599998 | 38.983261 | QAM256 | 17 |
18 | 275000000 | -0.500000 | 38.983261 | QAM256 | 18 |
19 | 283000000 | -0.599998 | 40.366287 | QAM256 | 19 |
20 | 291000000 | -0.599998 | 40.366287 | QAM256 | 20 |
21 | 299000000 | -1.000000 | 40.366287 | QAM256 | 21 |
22 | 307000000 | -2.000000 | 38.983261 | QAM256 | 22 |
23 | 315000000 | -2.200001 | 38.983261 | QAM256 | 23 |
24 | 323000000 | -2.200001 | 38.983261 | QAM256 | 24 |
26 | 339000000 | -1.799999 | 38.983261 | QAM256 | 26 |
27 | 347000000 | -1.700001 | 38.983261 | QAM256 | 27 |
28 | 355000000 | -1.799999 | 38.983261 | QAM256 | 28 |
29 | 363000000 | -1.900002 | 39.854763 | QAM256 | 29 |
30 | 371000000 | -1.299999 | 40.366287 | QAM256 | 30 |
31 | 379000000 | -1.700001 | 38.983261 | QAM256 | 31 |
25 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 40.946209 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.946209 | 0 | 0 |
15 | Locked | 40.366287 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 39.854763 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 42 | 2.2 | 439136844 | 0 |
on 06-08-2022 13:56
on 06-08-2022 17:04
on 06-08-2022 19:47
on 09-08-2022 13:33
Hello MattjVideos, thank you for reaching out and I am sorry to see you've been having some connection issues.
I have taken a look at our end and I can see there is an area outage in your local area.
Now this will can affect the whole connection and this is what will be causing your issues.
The end date for this is the 12th August at 15:00 as of right now.
I am sorry about any trouble this is causing. Thanks
Matt - Forum Team
New around here?
on 09-08-2022 19:49
on 10-08-2022 01:42
Hi @MattjVideos
If nothing is showing under Check Service Status you should also try the automated Service Status number on 0800 561 0061.
This usually gives details of more local issues down to postcode level.
