upload speed low and errors
graham1705
hi internet upload sped halfed was over 100 for a few days then droped and geting lots of us profile assessment change Untitledggg.png
30-08-2023 18:39:49warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:39:49noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:39:05noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:39:05warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:20noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:20warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:17noticeREGISTRATION COMPLETE - Waiting for Operational status
30-08-2023 18:38:10warningDynamic Range Window violation
30-08-2023 18:38:10warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:10warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:04noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:52warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:50noticeHonoring MDD; IP provisioning mode = IPv4
30-08-2023 18:37:37criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:33criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19 REPLIES 19
Post up the Hub data as per this...
____________________________
First click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.  Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
graham1705
12670000003.940QAM 25617
21390000007.840QAM 2561
31470000007.540QAM 2562
41550000007.540QAM 2563
51630000007.140QAM 2564
61710000006.840QAM 2565
71790000006.140QAM 2566
81870000006.140QAM 2567
91950000005.740QAM 2568
10203000000640QAM 2569
112110000005.740QAM 25610
122190000005.638QAM 25611
132270000005.439QAM 25612
14235000000540QAM 25613
152430000004.840QAM 25614
162510000004.340QAM 25615
172590000004.340QAM 25616
182750000003.840QAM 25618
192830000003.540QAM 25619
202910000004.340QAM 25620
212990000004.440QAM 25621
223070000005.340QAM 25622
233150000004.740QAM 25623
243230000005.540QAM 25624
253310000004.940QAM 25625
263390000005.740QAM 25626
273470000005.440QAM 25627
283550000005.840QAM 25628
293630000005.340QAM 25629
303710000005.840QAM 25630
313790000005.140QAM 25631
1Locked4013134010102
2Locked40559352618
3Locked401191516100
4Locked401221575905
5Locked401493754818
6Locked401922768792
7Locked401059318044
8Locked401022203420
9Locked401691626368
10Locked401123784703
11Locked40932584826
12Locked38606393794
13Locked391159829339
14Locked40772897636
15Locked4013644811671
16Locked40798004347
17Locked40540814218
18Locked40598304152
19Locked40531383364
20Locked40365503807
21Locked40419763645
22Locked40478004819
23Locked40536986625
24Locked40445534216
25Locked40313284040
26Locked40287543377
27Locked40384465821
28Locked40320574888
29Locked40302005895
30Locked40340804819
31Locked40289713739
04960000048.35120QAM 641
14310000048.35120QAM 642
23660000048.55120QAM 643
33010000049.35120QAM 644
42360000049.35120QAM 645
0ATDMA0200
1ATDMA0200
2ATDMA0200
3ATDMA0200
4ATDMA0220
01-09-2023 16:55:44warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 16:55:44warningDynamic Range Window violation
01-09-2023 16:18:27warningDynamic Range Window violation
01-09-2023 16:18:27warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 15:54:10warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 15:54:10warningDynamic Range Window violation
01-09-2023 14:54:30errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 13:49:21warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 13:49:21warningDynamic Range Window violation
01-09-2023 12:44:08warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 12:44:08warningDynamic Range Window violation
01-09-2023 12:14:31warningDynamic Range Window violation
01-09-2023 12:14:31warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 11:32:55warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 11:32:55warningDynamic Range Window violation
01-09-2023 10:55:38warningDynamic Range Window violation
01-09-2023 10:55:38warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 09:59:43warningDynamic Range Window violation
01-09-2023 09:59:43warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 08:58:29warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 08:58:29warningDynamic Range Window violation
01-09-2023 03:32:21warningDynamic Range Window violation
01-09-2023 03:32:21warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 00:09:40warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 00:09:40warningDynamic Range Window violation
31-08-2023 22:46:48warningDynamic Range Window violation
31-08-2023 22:46:48warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-08-2023 21:25:36warningDynamic Range Window violation
31-08-2023 21:25:36warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-08-2023 20:17:02warningDynamic Range Window violation
31-08-2023 20:17:02warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-08-2023 19:31:07warningDynamic Range Window violation
Legend
This is a concern if the error are still mounting up :
2Locked40559352618
3Locked401191516100
4Locked401221575905
5Locked401493754818
6Locked401922768792
7Locked401059318044
8Locked401022203420
9Locked401691626368
11Locked40932584826
graham1705
Would I engineer be able to fix the problems
graham1705
update more errors
12670000003.740QAM 25617
21390000007.439QAM 2561
31470000007.140QAM 2562
41550000007.140QAM 2563
51630000006.740QAM 2564
61710000006.540QAM 2565
71790000005.640QAM 2566
81870000005.640QAM 2567
91950000005.440QAM 2568
102030000005.740QAM 2569
112110000005.440QAM 25610
122190000005.338QAM 25611
132270000005.139QAM 25612
142350000004.840QAM 25613
152430000004.640QAM 25614
16251000000440QAM 25615
17259000000440QAM 25616
182750000003.639QAM 25618
192830000003.340QAM 25619
20291000000440QAM 25620
212990000004.140QAM 25621
223070000005.140QAM 25622
233150000004.540QAM 25623
243230000005.439QAM 25624
253310000004.739QAM 25625
263390000005.540QAM 25626
273470000005.240QAM 25627
283550000005.740QAM 25628
293630000005.140QAM 25629
303710000005.740QAM 25630
31379000000540QAM 25631
1Locked4020473513380
2Locked39683803391
3Locked401487437012
4Locked401295206416
5Locked401655745624
6Locked401986419418
7Locked401120828667
8Locked401269274447
9Locked401968607094
10Locked401342465713
11Locked401140155681
12Locked38804774763
13Locked3912642610258
14Locked4011966510431
15Locked4015166312122
16Locked40986675550
17Locked40696905071
18Locked39754735272
19Locked40592343533
20Locked40438714507
21Locked40449994252
22Locked40543325459
23Locked40600877422
24Locked39557135213
25Locked39508126420
26Locked40393674554
27Locked40407286422
28Locked40401315760
29Locked40380626850
30Locked40360135295
31Locked40341013963
upstream as a lot off t3 errors
04960000047.35120QAM 641
14310000047.35120QAM 642
23660000048.35120QAM 643
33010000048.35120QAM 644
42360000048.35120QAM 645
0ATDMA0210
1ATDMA0200
2ATDMA0210
3ATDMA0210
4ATDMA02180
You will get a Tech not an engineer and they do need to invesigate for "noise" getting in.
Lets see the BQM
graham1705
2 sep 2023
https://www.thinkbroadband.com/broadband/monitoring/quality/share/01ef9d362c3121d60629a6043f39370063ea9082-02-09-2023
graham1705
2nd sep2nd sep1 sep1 sep31st aug31st aug30th aug30th aug
BQM looks fine - no evidence of disconnects there - but PostRS error still building up needs investigation.
If nothing is being reported on    0800 561 0061    try calling it in as a fault - free on 150 (VM line)  or 0345 454 1111 others (national rate). See what they say when they test your connection. If they say it’s a known fault, get a fault reference number.  Or try and convince them that there is "noise" ingress causing the errors
Or, a VM person should pick this thread up and be able to help but it can take a few days.
