to Hub 1G to Desktop 400-500
Politegpig66
Hi there.
I am looking for any ideas as to what might be the problem.
Have 1gig for approx a year, about 6 months ago it started just going half that speed. Things go in the way and I didn't really do much about it.
However, I have had engineers out and cable changed, no difference.
Went from Modem mode to Orbi mesh back to Router on the hub 4.
Doing real Sam knows speed I get 1gig to hub but only 300/500 to desktop connected via cat 6 Ethernet.
I have changed the cables. rebooted, deleted Intel network card , removed any internet optimization software and back to default.
Still no difference. I have tried on another desktop and same difference.
Any ideas anyone? cheers Rich
11 REPLIES 11
Thank you echelom.
You sir are operating at Boss level.
15ms
900Mbps
First time!
Thanks everyone for chipping in with helpful advice.
THIS IS SOLVED!
thanks again
You're welcome, my friend!
I had similar problems myself, and just tried methods that worked for myself.
There were other commands that you could have tried but that one fixed two computers in our home.
