  • 546
  • 14
gareth170
Dialled in
Message 1 of 5
speed issue
hi
recently i have been having speed issues. i'm on 500Mb but i'm getting around 250Mb~.. i'm wondering if my area is starting to get high utilization again?
https://www.speedtest.net/my-result/d/803de8b1-fdfd-4b73-9f69-e3394ce2058e
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1299000000-1.237256 qam21
21390000000.937256 qam1
31470000000.537256 qam2
41550000000.237256 qam3
5163000000037256 qam4
6171000000038256 qam5
71790000000.237256 qam6
81870000000.537256 qam7
91950000001.537256 qam8
102030000002.937256 qam9
11211000000-237256 qam10
12219000000-2.237256 qam11
13227000000-237256 qam12
14235000000-2.237256 qam13
15243000000-3.537256 qam14
16251000000-337256 qam15
17259000000-237256 qam16
18267000000-1.537256 qam17
19275000000-1.738256 qam18
20283000000-1.738256 qam19
21291000000-1.537256 qam20
22307000000-1.238256 qam22
23315000000-138256 qam23
24323000000-138256 qam24
1Locked37.3661938504
2Locked37.6252572265091
3Locked37.6109247213213
4Locked37.694754219365
5Locked37.3235931338667
6Locked38.6128795508612
7Locked37.3114928364282
8Locked37.3140033258589
9Locked37.6112599339000
10Locked37.650630223818
11Locked37.3115226417079
12Locked37.6232897359400
13Locked37.6284714216726
14Locked37.3396645122130
15Locked37.632225662618
16Locked37.619832960915
17Locked37.626698185129
18Locked37.6309224170897
19Locked38.6307340177732
20Locked38.6239711110383
21Locked37.610687110264
22Locked38.61028348399
23Locked38.614567110374
24Locked38.610224911161
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1394000004.725512064 qam2
2326000004.65512064 qam3
3257999704.55512064 qam4
4461999954.775512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
  • 12.8K
  • 504
  • 1.16K
Message 2 of 5
Re: speed issue
Are you testing be wire?
Maybe try a new cable thats CAT6
500Mb is a big push by VM so high utilization in your area is possible.
  • 546
  • 14
gareth170
Dialled in
Message 3 of 5
Re: speed issue
i'm using wired CAT6 already. i've had 500Mb for many months before it came out to the public and i was getting full 500Mb+ but just recently i have been getting speed issues
  • 1.78K
  • 258
  • 712
Andruser
Super solver
Message 4 of 5
Re: speed issue
Your SNR and power levels look OK, but there looks like a problem with your error levels, and I'd guess that's resulting in lost packets, and re-transmits that are destroying your speed.
  • 546
  • 14
gareth170
Dialled in
Message 5 of 5
Re: speed issue
so what well be doing the errors?
i will reboot the hub and see if the errors come back.
My Broadband Ping - 500Mb
