on 24-07-2021 13:48
I have the M600 package, the router is currently set up downstairs and i have a powerline adapter to my gaming PC on the first floor and I am getting speeds of 70MBPS at best, I have spoken to technical support and they have told me there is nothing they can do other than send me a booster out which is for WI-FI, and log this with OFCOM. any help would be appreciated.
Thanks Paul
Answered! Go to Answer
on 24-07-2021 14:05
You need to test speed via a direct cabled connection. Powerline adapters are notorious for poor performance. Wifi tests are not acceptable either, so you should get a long ethernet Cat6 cable and setup a temporary connection for testing between the Hub and your PC.
on 24-07-2021 14:05
on 24-07-2021 21:19
hi, thanks for the help I will try this tomorrow and see how I get on if this still doesn't work ill be back on here again
on 25-07-2021 11:28
ok so I connected the PC directly to the hub this morning and the speeds are there, the fault is the powerline adapter, thank you for your help
on 26-07-2021 14:06
Hi Higgy89,
Thanks for getting back to us, and a very warm welcome to the Community Forum!
I'm glad that our Community Members have been able to help with this issue - if you need any further support, please don't hesitate to let us know, and we will try our best to help!
Kind regards,
Laurie
on 26-07-2021 21:16
Hi Laurie,
the community members are great it solved my problem rapid, better than technical on the phone, wont waste my time ringing them again. ill come straight on here.
thanks guys
