iac1
slow speed
Hi there ,
I have 200 Mbps internet speed with my package but I have for couple days only 35-40 Mbps.
I already reboot the Virgin hub but nothing change,please help me.
Laszlo
  • 3.57K
  • 425
  • 1.13K
Re: slow speed
Hi Lazlo
Are you using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so a wired test is the best way to get a true picture of what speed your line is able to achieve. It also helps to pinpoint if the issue is with the wireless or your line.
______________________
Scott
Disclaimer - I don't work for Virgin Media. I'm just another VM user trying to help out.
My setup: V6 TV box, Vivid 200 Optical fibre with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
  • 569
  • 18
  • 31
Re: slow speed
Hi iac1,
Thank you for getting in touch and welcome to the community Smiley Happy
I am sorry to hear you are experiencing problems with the speed of your service.
Can you please confirm the following for me?
- Is this a Hub 3?
- Are you only having this problem when connected to the internet via WiFi?
- Is this on just the one device?
- Where is your Hub? Is it in a good location and not blocked by other devices/objects?
- Have you ran a speed test via a laptop/ PC on a wired and wireless connection?
Let me know and I will be happy to look in to this further Smiley Happy
Nat
