jjhj02
Message 1 of 8
slow broadband speed
Can anyone help please?
TERRIBLY SLOW download speeds.
Usually under 10mbps
Occasionally under 2
Sometimes, very rarely, over 20.
We are on 200 and GUARANTEED NEVER UNDER 107.
DOES ANYONE KNOW HOW TO GET A REIMBURSEMENT FOR YEARS OF FAILURE BY VIRGIN TO SUPPLY WHAT WE HAVE BEEN PAYING FOR?
2. And how can we get a technician to visit to test the hub and give us a diagnosis?
We are DESPERATE as our broadband is PATHETIC and useless all evening and much of the day. We live in a city with cable under the pavements.
Jonathan
Anonymous
Not applicable
Message 2 of 8
Re: slow broadband speed
Wired or wireless devices?
Could you access your router using http://192.168.0.1/ . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
jjhj02
Message 3 of 8
Thanks Carl.
I couldn't get to the page of 'Check Router Status'. Are you sure it is visible?
Anonymous
Not applicable
Message 4 of 8
What version of the HUB do you have?
jjhj02
Message 5 of 8
Hub 3. Wired connection.
I saw the pic you added to your msg.
Maybe I should log in?
Anonymous
Not applicable
Message 6 of 8
Have you ever logged in?
Maybe you still need to enter the setup menu, by logging in!
jjhj02
Message 7 of 8
No, I'll try.
Anonymous
Not applicable
Message 8 of 8
Password on the base of the HUB. You'll be prompted to change it.
