stuodon
slow broadband speed
hi, i've recently done a speed test on my network and found that it has dropped by approx 90%, can someone tell me why this is.here is my router log. Thanks.
the speed test showed 7.99 down and upload 0.29
1 299000000 1.7 38 256 qam 21
2 139000000 3.2 38 256 qam 1
3 147000000 3 40 256 qam 2
4 155000000 3 40 256 qam 3
5 163000000 2.9 40 256 qam 4
6 171000000 3 38 256 qam 5
7 179000000 2.9 38 256 qam 6
8 187000000 3 38 256 qam 7
9 195000000 2.7 38 256 qam 8
10 203000000 2.5 38 256 qam 9
11 211000000 2.5 38 256 qam 10
12 219000000 2.4 40 256 qam 11
13 227000000 2.2 38 256 qam 12
14 235000000 2.2 38 256 qam 13
15 243000000 2 38 256 qam 14
16 251000000 2 38 256 qam 15
17 259000000 1.7 38 256 qam 16
18 267000000 1.7 38 256 qam 17
19 275000000 1.5 40 256 qam 18
20 283000000 1.5 38 256 qam 19
21 291000000 1.5 38 256 qam 20
22 307000000 1.5 38 256 qam 22
23 315000000 1.5 38 256 qam 23
24 323000000 1.5 38 256 qam 24
1 Locked 38.9 3739 0
2 Locked 38.9 1228 0
3 Locked 40.3 30 0
4 Locked 40.3 706 0
5 Locked 40.9 104 0
6 Locked 38.9 4054 0
7 Locked 38.9 8 0
8 Locked 38.6 173 0
9 Locked 38.9 19 0
10 Locked 38.9 1137 0
11 Locked 38.9 8 0
12 Locked 40.3 1244 0
13 Locked 38.9 73 0
14 Locked 38.9 7632 0
15 Locked 38.9 11 0
16 Locked 38.9 166 0
17 Locked 38.9 24 0
18 Locked 38.9 1050 0
19 Locked 40.3 8 0
20 Locked 38.9 639 0
21 Locked 38.9 39 0
22 Locked 38.9 11 0
23 Locked 38.9 179 0
24 Locked 38.9 21 0
1 53700000 3.393 5120 64 qam 11
2 25799995 3.275 5120 64 qam 10
3 32599942 3.3 5120 64 qam 9
4 39400175 3.35 5120 64 qam 8
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u+voc-b.cm
SFID 142258
Max Traffic Rate 115000000
Max Traffic Burst 10000
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 142257
Max Traffic Rate 6320000
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
25/03/2019 13:06:18 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2019 08:48:57 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2019 21:33:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2019 23:00:2 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2019 23:06:30 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2019 10:04:23 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2019 11:27:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2019 13:12:56 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2019 15:36:33 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2019 21:08:47 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2019 23:12:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2019 14:27:46 notice Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2019 14:45:55 Error Map Request Retry Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30 Warning! MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2019 15:09:49 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:29 Warning! MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:29 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2019 15:44:17 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 573
  • 28
  • 45
Re: slow broadband speed
Hi there,
Sorry for the delayed reply.
What speeds are you getting and subscribed too please? Also, how are you testing the speed, wired/wireless?
Kind regards,
stuodon
Hi, thanks for replying, all sorted now, was something in windows 7 that was restricting full power of nic,just reinstalled an image of c drive and everything working as it should now. thanks again
  • 398
  • 17
  • 39
Hi stuodon,
Thank you for coming back to us.
I am really glad you managed to sort out your issue, It may be worth adding a full post with issue and how you fixed it so anyone else with the same issue may use it.
Many thanks.
Paul.
