on 27-11-2021 11:11
I have just received my gig1 hub and I am having some issues. Firstly, the Hub 4 light strip does not illuminate at all. There is no difference when turned on or off. I've tried changing the brightness in the settings, but it makes no difference.
However, when the unit is powered, it connects to the internet, WiFi and ethernet function.
My second issue is that previously I was on a 500mbps connect with Virgin Business and my typical download speeds were 540mbps. On the gig1 service I am seeing a maximum of 360mbps when measured by RealSpeed - SamKnows which was what the Virgin engineer told me to use.
My previous Virgin router had a 10db attenuator attached, however I've been led to believe that this is no longer supported, so I have removed it. My power levels are now scarily high.
I've spoken to Virgin help desk 3 times and so far, all they say is that "I have sent along a signal and all will be better after that." It hasn't made a difference. When I run the automated tests at Service Status - My Virgin Media it tells me that:
We're going to send a signal to the Hub in order to fix things. This will take about 10 minutes and cause the Hub to restart.
I've tried this several times and nothing is ever fixed.
Can anyone help me get this resolved?
BTW, the key information from the Hub 4 is as below:
25 | 331000000 | 9.900002 | 38.983261 | QAM256 | 25 |
17 | 267000000 | 9.599998 | 40.366287 | QAM256 | 17 |
18 | 275000000 | 9.199997 | 38.983261 | QAM256 | 18 |
19 | 283000000 | 9.699997 | 38.983261 | QAM256 | 19 |
20 | 291000000 | 10.599998 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 10.699997 | 38.983261 | QAM256 | 21 |
22 | 307000000 | 10.500000 | 38.983261 | QAM256 | 22 |
23 | 315000000 | 9.800003 | 38.983261 | QAM256 | 23 |
24 | 323000000 | 9.900002 | 38.983261 | QAM256 | 24 |
26 | 339000000 | 9.800003 | 38.605377 | QAM256 | 26 |
27 | 347000000 | 9.699997 | 38.605377 | QAM256 | 27 |
28 | 355000000 | 9.400002 | 38.605377 | QAM256 | 28 |
29 | 363000000 | 9.500000 | 38.605377 | QAM256 | 29 |
30 | 371000000 | 9.300003 | 38.605377 | QAM256 | 30 |
31 | 379000000 | 9.500000 | 38.983261 | QAM256 | 31 |
32 | 387000000 | 9.400002 | 38.983261 | QAM256 | 32 |
33 | 395000000 | 9.300003 | 38.983261 | QAM256 | 33 |
34 | 403000000 | 9.099998 | 38.605377 | QAM256 | 34 |
35 | 411000000 | 9.000000 | 38.983261 | QAM256 | 35 |
36 | 419000000 | 8.500000 | 38.605377 | QAM256 | 36 |
25 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.605377 | 0 | 0 |
27 | Locked | 38.605377 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
29 | Locked | 38.605377 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
33 | Locked | 38.983261 | 0 | 0 |
34 | Locked | 38.605377 | 0 | 0 |
35 | Locked | 38.983261 | 0 | 0 |
36 | Locked | 38.605377 | 0 | 0 |
37 | 96 | 4K | 1880 | QAM4096 | 424 |
37 | Locked | 40 | 8.2 | 781101 | 0 |
1 | 32600000 | 37.270599 | 5120 KSym/sec | 64QAM | 10 |
2 | 53700000 | 38.270599 | 5120 KSym/sec | 64QAM | 7 |
3 | 39400000 | 37.520599 | 5120 KSym/sec | 64QAM | 9 |
4 | 46200000 | 37.770599 | 5120 KSym/sec | 64QAM | 8 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
Answered! Go to Answer
on 08-12-2021 14:16
Hi there,
Just to update the public thread we have now arranged an engineer to attend and replace the Hub.
Please @doverton do let us know how things are after the appointment.
Thanks again.
