  • 21
orionpax
Message 1 of 29
constant disconnects and poor speeds
Getting really poor speeds and disconnects [ 6 times so far today ] Recently upgraded to 350mb even had a engineer come to fix which lasted a like 2 days. any help with this would be great. also attaching a picture of most of my speeds tests as you'll there pretty poor for the most part.
  • 8.98K
  • 923
  • 1.4K
Message 2 of 29
Re: constant disconnects and poor speeds
Are your disconnects only occurring on wifi or do ethernet cable connected devices also disconnect at the same time? Can you check over wire if you havent?
  • 21
orionpax
Message 3 of 29
yeah its wired.
  • 8.98K
  • 923
  • 1.4K
Message 4 of 29
@orionpax wrote:
yeah its wired.
OK - Try this then.
Check all your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc and that the internal wiring is ok with no kinking or chaffing (rabbit chews!).  Also check that all looks good with the outside cabling and wall box.  If that’s all good post up your Hub/network connection details and someone will check to see if there is a problem there.  Go to http://192.168.0.1  (or http://192.168.100.1  - if in modem mode) in your browser [there is no need to login] and then click on the  “router status” text at bottom middle of first page up and then copy/paste 3 sets of data onto here - the downstream, upstream , &  network logs.  Don't worry about the formatting it can be easily read, but try to avoid using screen shots & don’t include personal data or mac addresses - blank them out.
  • 21
orionpax
Message 5 of 29
Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
1	299000000	2	37	256 qam	21
2	323000000	2.2	37	256 qam	24
3	315000000	0.9	37	256 qam	23
4	307000000	0.4	37	256 qam	22
5	291000000	2.2	37	256 qam	20
6	283000000	1.5	37	256 qam	19
7	275000000	1.5	33	256 qam	18
8	267000000	2.7	32	256 qam	17
9	259000000	2.7	34	256 qam	16
10	251000000	1.7	37	256 qam	15
11	243000000	2	37	256 qam	14
12	235000000	2.2	37	256 qam	13
13	227000000	3	30	256 qam	12
14	219000000	3	35	256 qam	11
15	211000000	3	37	256 qam	10
16	203000000	3.2	35	256 qam	9
17	195000000	3.5	35	256 qam	8
18	187000000	2.7	34	256 qam	7
19	179000000	3.5	33	256 qam	6
20	171000000	3.7	34	256 qam	5
21	163000000	4.6	33	256 qam	4
22	155000000	4.4	35	256 qam	3
23	147000000	1.5	33	256 qam	2
24	139000000	2.2	35	256 qam	1
  • 21
orionpax
Message 6 of 29
Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
1	Locked	37.3	1740743	63
2	Locked	37.3	1937335	128
3	Locked	37.3	3554016	78
4	Locked	37.6	34854	64
5	Locked	37.6	13730122	66
6	Locked	37.3	11683	83
7	Locked	33.3	96518553	2953
8	Locked	32.6	72676808	38955047
9	Locked	34.3	37665300	164
10	Locked	37.3	32166	143
11	Locked	37.6	705	170
12	Locked	37.3	3112	298
13	Locked	30.2	65808225	359311
14	Locked	35.5	734165	269
15	Locked	37.6	1200	92
16	Locked	35.7	3894671	85
17	Locked	35	3041695	139
18	Locked	34.3	532860	241
19	Locked	33.3	867634	270
20	Locked	34.4	177658	197
21	Locked	33.9	153957	256
22	Locked	34.9	1483159	418
23	Locked	33.8	73719898	431
24	Locked	34.9	25290140	264
Channel	Frequency (Hz)	Power (dBmV)	Symbol Rate (ksps)	Modulation	Channel ID
1	46200000	40.5	5120	16 qam	1
2	25800000	37.8	5120	16 qam	4
3	32600000	38.8	5120	16 qam	3
4	39400000	39	5120	16 qam	2
Channel	Channel Type	T1 Timeouts	T2 Timeouts	T3 Timeouts	T4 Timeouts
1	ATDMA	0	0	0	0
2	ATDMA	0	0	0	0
3	ATDMA	0	0	0	0
4	ATDMA	0	0	0	0
Time	Priority	Description
2018-12-09 18:03:52.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:04:09.00	Warning!	RCS Partial Service;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:05:25.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:05:29.00	Warning!	RCS Partial Service;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:06:04.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:06:12.00	Error	Service Change Response rejected - Invalid transaction ID;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:07:58.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:08:29.00	Error	Service Add Response rejected - Invalid transaction ID;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:09:25.00	Warning!	RCS Partial Service;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:10:20.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:11:27.00	Warning!	RCS Partial Service;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:15:06.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:16:37.00	Error	DCC-ACK rejected authentication failure;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:16:52.00	Warning!	RCS Partial Service;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:17:25.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:18:49.00	Error	Service Add Ack rejected - Invalid transaction ID;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:19:14.00	Warning!	RCS Partial Service;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:19:52.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:21:22.00	Warning!	RCS Partial Service;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
2018-12-09 18:22:30.00	Warning!	Lost MDD Timeout;CM-MAC=;CMTS-MAC=:eb;CM-QOS=1.1;CM-VER=3.0;
 also dc'd twice while getting this info :C
  • 5.3K
  • 105
Moderator (Retired) Ty_S
Moderator (Retired)
Message 7 of 29
Hi orionpax
I'm really sorry to hear that you've still been experiencing intermittent connection. I'll certainly look into this for you.
I’ve run some checks on your hub and everything looks healthy at the moment. I can’t see any tickets open for any issues in your area either. Are you still experiencing these drop outs and slow speeds?
Speak soon,
  • 21
orionpax
Message 8 of 29
Hi, normally get like 8-40mb through the week at peak times naturally, and disconnects mainly happen at the weekends with really low speeds whens its on. like last Saturday i had 11 dc's between 1pm - 10pm they last about 15 mins then comes back on also had one for about an hour then was top speeds from 10 on wards. will also post speed test results later if i get any low speeds through the night as an idea of what happens.
  • 21
orionpax
Message 9 of 29
tonight's speeds 😕
  • 21
orionpax
Message 10 of 29
Todays low speeds. :C
