pmchoc
  • 23
connection issues
Hi all
Ive had some issuesd where the connection pauses and for the last two days has dropped at 07:42 AM. Reset hub (its in modem mode) but still seems to have issue with 'pausing' in the day.
Log Below
19/11/2020 07:42:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 23:33:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 07:42:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2020 09:24:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 21:00:16noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 21:00:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 22:06:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 09:00:16noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 09:00:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 21:16:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 19:41:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:29:8noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:24:23criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:23:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:23:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:21:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:15Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:52Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
pmchoc
  • 23
Re: connection issues
power levels below:
1259000000-1.437256 qam16
2139000000337256 qam1
31470000002.537256 qam2
41550000002.437256 qam3
51630000002.238256 qam4
61710000001.937256 qam5
71790000001.537256 qam6
81870000001.238256 qam7
91950000000.938256 qam8
102030000000.537256 qam9
112110000000.237256 qam10
12219000000037256 qam11
13227000000-0.237256 qam12
14235000000-0.737256 qam13
15243000000-137256 qam14
16251000000-1.437256 qam15
17267000000-137256 qam17
18275000000-0.737256 qam18
19283000000-0.237256 qam19
20291000000-0.737256 qam20
21299000000-0.737256 qam21
22307000000-137256 qam22
23315000000-0.937256 qam23
24323000000-0.438256 qam24
1Locked37.360
2Locked37.6220
3Locked37.6190
4Locked37.6180
5Locked38.660
6Locked37.350
7Locked37.670
8Locked38.260
9Locked38.640
10Locked37.640
11Locked37.640
12Locked37.650
13Locked37.360
14Locked37.610
15Locked37.650
16Locked37.370
17Locked37.350
18Locked37.360
19Locked37.600
20Locked37.660
21Locked37.670
22Locked37.640
23Locked37.690
24Locked38.940
13260000045512064 qam3
22579998345512064 qam4
33940002645512064 qam2
44619994445512064 qam1
3ATDMA0000
4ATDMA0000
pmchoc
  • 23
Also (if it matters) getting to the hub and logged on is hit and miss, most times the page doesnt respond, or i get logged in then it times out (192.168.100.1)
