13-01-2022 19:42 - edited 13-01-2022 19:45
I have just upgraded (10/01/22) to the 1 gig and I have managed to get the Sam knows speed test to work and it doesn't seem like I'm getting the speed to the hub.
I'm basically getting the same as before the upgrade.
Answered! Go to Answer
on 13-01-2022 20:54
@spacecadetuk wrote:Thanks.
I take if that doesn't work it's a phone call to customer services :☹️
Yeah... I know... Not exactly something to look forward to!
on 13-01-2022 21:11
Tried a reset of the router, still the same. Thanks for your help though.
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | 54k;fg87dsfd;kfoA,.iyewrk |
SFID | 32640 |
Max Traffic Rate | 690000278 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 32639 |
Max Traffic Rate | 44000278 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
If anyone from the forum team can pick this up and save me a call to customer service it would be appreciated.
on 13-01-2022 21:15
You could try the live chat, which pops up on the right hand side:
https://www.virginmedia.com/broadband
on 16-01-2022 16:16
Hi spacecadetuk,
Thanks for your post and apologies to hear you're getting lower speeds that you were expecting.
Taking a look at the account, I can see why the speeds are topping out. In order to discuss this further with you, I'll need to pass data protection with you. I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
on 17-01-2022 19:32
I rang customer service as requested and was told there is a problem but she would push the config file to the router and reboot it remotely.
When I got home I checked and it is still the same.
I have since rebooted and reset the router but it is still the same.
DOCSIS Mode | 3.1 |
Config file | kfoA,.iyewrkldJKDHSUBsgvc |
SFID | 32640 |
SFID | 32639 |
Thu Jan 1 00:01:29 1970 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Jan 17 19:12:56 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 17-01-2022 19:42
@spacecadetuk oh, and you believed what VM offshore customer services told you? Ah bless!
Joking aside, what does your online account say you should be on and indeed being billed for?
on 17-01-2022 19:46
on 17-01-2022 20:23
So you are being billed for a 1 Gig connection but they are not supplying it? Trading standard anyone…..
on 17-01-2022 21:45
@spacecadetuk wrote:Hi
I have just upgraded (10/01/22) to the 1 gig and I have managed to get the Sam knows speed test to work and it doesn't seem like I'm getting the speed to the hub. <snip>
Just noticed your last post shows you are a VOLT upgrade. These take 14 days to activate on the VM side. Also make sure your O2 and VM accounts are in the exact same Name and Address etc. or the upgrade may fail.
on 20-01-2022 17:13
Hi @spacecadetuk,
Thank you for coming back to us. How are your speeds getting on since you last spoke to my colleague? Have you had a look at SamKnows recently to see what you're receiving?
Let us know if there's anything further we can help with in the meantime. 🙂
Thank you.
