If it's guidance on something you can do yourself, you may get what you need from the membership of this forum.
If it's something that has to be actioned by VM, the chat service has not proved to be particularly effective, but some do seem to have more luck with the text service.
Depending on the nature of your problem, you may also get an interjection from a helpful VM employee here.
M350 over FTTP
