on 30-12-2022 18:00
Since swapping for my 1000mb hub 4 to the 1000mb hub 5 my Xbox series x can only get 200mb connection now , the hub 4 I could get over 500mb ,
apart from changing the router nothing else has changed , but now at best I can get a max of 200mb..
anybody know of any fixes ? With the hub 5 being WiFi 6 and only being 3 metres from the Xbox I thought connection would be solid and speeds would be better ,
on 30-12-2022 21:06
Does your Xbox have wifi 6? If not you will not get faster speeds from a wifi 6 router. And there have been reports of poor speeds from the Hub 5 with some wifi 5 devices.
30-12-2022 21:40 - edited 30-12-2022 21:43
@K2soljaz wrote:Since swapping for my 1000mb hub 4 to the 1000mb hub 5 my Xbox series x can only get 200mb connection now , the hub 4 I could get over 500mb ,
No WiFi 6
https://turbospeedwifi.com/does-the-xbox-series-x-have-wi-fi-6/
I'd suggest accessing the HUB and checking the 'Connected Devices' section to the see the speed (Mbps) the device is connecting at.
on 30-12-2022 22:47
At only 3 metres distance, why not use a cable? Ethernet will always give the best connection.
on 31-12-2022 06:52
Becuase id have to have an Ethernet cable going across the middle of the room . It wouldn’t be practical,
on 31-12-2022 06:53
It’s just strange how the hub 4 seems the better and faster hub than the hub 5
on 31-12-2022 10:34
There's been a number of problems with the Hub 5, reported on these forums.
on 31-12-2022 10:54
Looks like virgin need to push a firmware/software update out then..
on 31-12-2022 18:40
same here bud' since upgrading to the hub 5 our speeds have been worse we are meant to be on 250MB and we are getting 35MB to put it simple virgin media do not care about their customers it seems to me as long as there getting your money they're could not care less about this crumbling network correct me if i'm wrong but this network seems to have gotten worse since O2 joined forces
on 01-01-2023 18:36
Yes , looks like I’ll have to put my Virgin router into modem mode and use my own router..
that’s the only way around it.
