ris9267
Wired and wifi connection applied
Hi everyone I pay for 350 mbps but I only get 200 can someone explain this too me. It is only used in one room in my home and runs tv and iPhone at this moment but I have iPad coming and iMac on its way which will also be connected other than iPad and iPhone everything will be wired oh also I have firestick4K I use a lot but this also only 200mbps sometimes less also when using ipvanish sometimes only get a 3rd of the speeds can anyone help me.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Wired and wifi connection applied
Forget Wi-Fi speeds, they aren't accurate enough.
What speed do you get at >> speedtest.net << using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
