Fin1988
Message 1 of 7
Wifi
I Have purchased a 1gig fibre connection and I have a issue so I rang up and got a wifi booster I Ethernet the booster to my pc but I only get a 1 mbps upload and a 200 kbps download
Can someone pls help thanks
  • 33.84K
  • 3.32K
  • 6.43K
Message 2 of 7
Re: Wifi
What do you get on a computer/laptop connected to the Hub on a Cat5e/6 ethernet cable?
Fin1988
Message 3 of 7
Re: Wifi
I get the same 1mbps upload and 200kbos download
Fin1988
Message 4 of 7
Re: Wifi
KBPs
  • 6.11K
  • 514
  • 1.58K
Message 5 of 7
Re: Wifi
Wired directly to the Hub with a Cat6a cable??  Don’t use the power line adapters.
  • 33.84K
  • 3.32K
  • 6.43K
Message 6 of 7
Re: Wifi
Can you test speeds this way....
__________________________
As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode” (https://www.virginmedia.com/help/virgin-media-hub-modem-mode ). This ensures that NO other devices are connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
Alex_RM
  • 6.71K
  • 347
  • 504
Message 7 of 7
Re: Wifi
Hi Fin1988,
Thanks for posting and welcome to our community 🙂
Sorry to hear you've had some issues with your speeds. Have you been able to test the speeds as jbrennand has advised?
Alex_Rm
