  • 7
grob2011
Where's our Speed boost?
got boosted broadband and phone and sim on vivid 50 but no boost i,m still on 50 mps
the hub is still on 50mps
  • 101
  • 7
  • 20
chrisxp
Up to speed
Re: Where's our Speed boost?
Hi there,
Can you please go to http://192.168.0.1/ or http://192.168.100.1/ if you have the superhub in modem mode.
Don't login, just click "Check router status" at the bottom. From here, under the configuration tab, can you let us know the config file value please?
For example, I'm on 500Mb and mine is "cmreg-vmdg505-rtsxxxl500u+voc-b.cm"
Happy Virgin Customer
If you like my answer please give "Kudos" (thumbs up) and if it's helpful please mark it as "Accepted Solution".
  • 938
  • 43
  • 121
happywithmy350
Well-informed
oh - this thread again - you like starting more than 1 don't you...
  • 7
grob2011
The router only shows downstream and upstream
Downstream 57500000
Upstream 3170000
57.5mps and 31.7 mps
  • 938
  • 43
  • 121
happywithmy350
Well-informed
But if you are on vivid 50 then you should be on 57.5 down! - you shouldn't however be getting 31.7 up so what are you bothered about? if you are going to get 31mbps up on 50mbps down i'll downgrade as will many others as some only pay for top tier to get the upload!
  • 12.56K
  • 482
  • 1.12K
Its 3.1 Mb upload for 50Mb.
