jaaybee89
What wifi speed should i get?
I'm on m600 fiber (hub 3)and get between 80 and 250mbps occasionally dropping as low as 30mbps. However running a wired connection to xbox series x the console speed test is between 500 and 800mbps. I know wifi is slower but should it be this much slower?
Also the wifi connection cuts out for a second or two a few times every day, its a real pain when playing online games as you get removed from the game.
Thanks.
  • 22.38K
  • 2.4K
  • 3.99K
Re: What wifi speed should i get?
Depends on what devices you are connecting on wifi and what their speed capabilities are - and also whether they are connecting on the 2.4 or 5 GHz bands?
Have you tried separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings and at the same time switch off "channel optimisation" Then use a wifi scanning App to find the best 2.4 wifi channels to use (just use 1,6,11) — that often helps Hub3 users get better wifi performance
Are the drops just on wifi or do they occur at the same time on ethernet connections?
jaaybee89
The drops are on wifi, the wired devices very rarely experience the momentary drops but the speed does vary along.
Thanks for your advise.
jaaybee89
Update.
I've applied all your suggestions, separated the ids, and run a wifi scanner and switched to the suggested channels and disabled the optimisation.
On 2.4ghz  average down is now 90mbps
On 5.0ghz average down is now 160mbps
Too early to say if still getting dips.
Honestly the wifi has been bad ever since it was installed, I mean since they put the connection into the house from the road. I've contacted support many times and an engineer has been out 3 or 4 times, at this point I think I'm going to cancel my contract. I know the speeds I'm getting are still pretty fast but I'm paying for a service that isn't being provided.
  • 22.38K
  • 2.4K
  • 3.99K
See message 14 in thus recent thread
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-connection/td-p/4678825/page/2
mjpartyboy
  • 292
  • 17
  • 31
Fibre optic
The speed being delivered to the Super Hub is what you're paying for. From there, many things can affect the bandwidth different devices receive.
SH2 modem mode | AC86U router | AC68U node
