Whoops - big edit as I'd not read your last post:
Your network log is stuffed full of RCS Partial Service and Synchronisation errors. That can only be caused by a VM cable or equipment fault causing sufficient noise (usually but not always on the upstream) resulting in the hub losing connection on one or more channels until it can reestablish a proper connection. Whilst resetting your ethernet controller speed might have unthrottled your connection, those errors will be causing slow down and unreliable connection if they're still occurring at that frequency.
That problem might be a known area fault affecting other customers (the "best" sort of problem, since they're usually fixed without you needing to do anything and without a property visit), and indeed it may already have been fixed. If not, then it'll require a visit to your property by a VM technician. If they just replace the hub and head off, then be assured that they won't have found and fixed the fault - I've yet to see those symptoms fixed by a replacement hub, but that's a quick, easy (and ineffectual) effort when staff are not permitted sufficient job time to properly find and fix problems.
I would suggest you don't try and phone this in, if you get the useless offshore bunch (a) they won't understand the problem properly, and (b) after a restart the hub will 99% of the time work OK for a while, so they'll call that a fix and and close the problem. Instead, hold on here (sometimes can be a day or two) for VM staff to pick this up and advise.
Hopefully VM staff won't say "looks good from our side" because it patently doesn't - the reported power, modulation and SNR might be within limits, but the network log PROVES that there's a serious technical issue disrupting communication between the CMTS and the hub.
