on 06-02-2022 12:48
I was previously unable to utilise my volt benefit with Virgin and o2 in January as I was on the maximum speed at my postcode.
Faster speeds are now available at my property so how do I get my volt benefit applied now?
When I speak to the service advisors on the phone they all try and make me sign up to a new contract!!!
thanks
craig
on 06-02-2022 14:22
Try posting in this section of the Forum. Managing Your Account - Cable - Virgin Media Community
on 09-02-2022 08:58
Hi Cjeffries,
Thank you for your post.
If the speed is eligible at your property then it shouldn't be a problem at all. Just to confirm, have you been able to have this amended since your post?
Cheers,
Ryan.
