on 30-10-2021 11:32
Hello,
I was previously on M100 Broadband. No problems there, it's very stable. I have just upgraded to Volt M200. I was advised it had been done yesterday and, indeed, my account shows Volt M200 as my broadband package.
However, I am still only getting 100meg. I have restarted my router too.
Here are the service flow stats
SFID | 32650 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 32629 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
on 30-10-2021 12:45
Looks like your HUB hasn't received a new config file as yet.
on 30-10-2021 15:19
That's what I figured. I was hoping someone could tell me how long it takes for the config to come down.
on 30-10-2021 15:32
Usually at the point your new contract starts.
Are you getting a new HUB aswell?
on 30-10-2021 17:39
Not that I know of. Oh well, just wait and see I guess. My account says I'm on M200 so I thought the config would have been done at the same time.
on 01-11-2021 15:03
Any Virgin Media people around to assist please?
Thanks.
on 01-11-2021 16:49
This is crazy. Just got the config pushed down to my router and I get lower speeds than I did on M100.
M100 was a solid 100+ meg all the time.
Upgrade to Volt M200 and it's dropped to between 70 and 90 meg.
SFID | 32650 |
Max Traffic Rate | 230000061 |
SFID | 32629 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Cable Modem StatusItemStatusCommentsAcquired Downstream Channel (Hz)
Ranged Upstream Channel (Hz)
Provisioning State
1 | 515000000 | 12.8 | 40 | 256 qam | 36 |
2 | 235000000 | 13.6 | 40 | 256 qam | 13 |
3 | 243000000 | 13.6 | 40 | 256 qam | 14 |
4 | 251000000 | 13.8 | 40 | 256 qam | 15 |
5 | 259000000 | 13.6 | 40 | 256 qam | 16 |
6 | 267000000 | 13.6 | 40 | 256 qam | 17 |
7 | 275000000 | 13.6 | 40 | 256 qam | 18 |
8 | 283000000 | 13.8 | 40 | 256 qam | 19 |
9 | 291000000 | 13.6 | 40 | 256 qam | 20 |
10 | 299000000 | 14 | 40 | 256 qam | 21 |
11 | 307000000 | 14 | 40 | 256 qam | 22 |
12 | 315000000 | 14 | 40 | 256 qam | 23 |
13 | 323000000 | 14.1 | 40 | 256 qam | 24 |
14 | 331000000 | 14.1 | 40 | 256 qam | 25 |
15 | 339000000 | 14 | 40 | 256 qam | 26 |
16 | 347000000 | 13.9 | 40 | 256 qam | 27 |
17 | 355000000 | 13.8 | 40 | 256 qam | 28 |
18 | 363000000 | 13.6 | 40 | 256 qam | 29 |
19 | 371000000 | 13.9 | 40 | 256 qam | 30 |
20 | 379000000 | 14 | 40 | 256 qam | 31 |
21 | 387000000 | 14.1 | 40 | 256 qam | 32 |
22 | 491000000 | 12.8 | 40 | 256 qam | 33 |
23 | 499000000 | 12.6 | 40 | 256 qam | 34 |
24 | 507000000 | 12.5 | 40 | 256 qam | 35 |
1 | Locked | 40.9 | 0 | 0 |
2 | Locked | 40.3 | 5 | 0 |
3 | Locked | 40.9 | 4 | 0 |
4 | Locked | 40.3 | 5 | 0 |
5 | Locked | 40.9 | 4 | 0 |
6 | Locked | 40.9 | 5 | 0 |
7 | Locked | 40.9 | 4 | 0 |
8 | Locked | 40.9 | 6 | 0 |
9 | Locked | 40.9 | 5 | 0 |
10 | Locked | 40.9 | 3 | 0 |
11 | Locked | 40.3 | 6 | 0 |
12 | Locked | 40.3 | 5 | 0 |
13 | Locked | 40.3 | 4 | 0 |
14 | Locked | 40.3 | 6 | 0 |
15 | Locked | 40.9 | 5 | 0 |
16 | Locked | 40.3 | 4 | 0 |
17 | Locked | 40.3 | 5 | 0 |
18 | Locked | 40.3 | 4 | 0 |
19 | Locked | 40.3 | 4 | 0 |
20 | Locked | 40.3 | 5 | 0 |
21 | Locked | 40.3 | 6 | 0 |
22 | Locked | 40.9 | 0 | 0 |
23 | Locked | 40.3 | 12 | 0 |
24 | Locked | 40.9 | 6 | 0 |
1 | 39400017 | 36.5 | 5120 | 64 qam | 10 |
2 | 25799996 | 36.5 | 5120 | 64 qam | 12 |
3 | 32600019 | 36.5 | 5120 | 64 qam | 11 |
4 | 46199981 | 36.5 | 5120 | 64 qam | 9 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 01-11-2021 17:57
Your power levels are too high and will need adjusting with a either an engineer visit or one of these:
on 01-11-2021 18:41
All sorted. Switched absolutely everything off for a few minutes. Then switched on Router, Switch and then devices.
Now getting max speeds.
I've added an attenuator for good measure but not needed it before.
Thanks.
01-11-2021 18:45 - edited 01-11-2021 18:46
Fair enough.
Your power levels should be between -6 and +10dBmV.
Not sure what they are now?
