BenMyatt
Message 1 of 5
Vivid 350 speed
Having just upgraded from vivid 200 to vivid 350 I'm not getting anywhere near expected download speed. I get between 75Mbps and 138Mbps down but 21Mbps up.
I use my hub 3 in modem mode connected to an Amplifi router (mesh network).
I have attached my modem upstream and downstream configuration for advice on what to check next?
  • 24.99K
  • 1.04K
  • 3.97K
Message 2 of 5
Re: Vivid 350 speed
are you testing speeds wired or wireless?
  • 521
  • 22
  • 67
happywithmy350
Rising star
Message 3 of 5
Re: Vivid 350 speed
Erm..
That would be wireless no?
BenMyatt
Message 4 of 5
Re: Vivid 350 speed
Hi. I always check wired. Also my router has an inbuilt network throughput test tool. This is where I predominantly get my speed test results from.
Most recent test below with download at just 47Mbps
BenMyatt
Message 5 of 5
Re: Vivid 350 speed
The router is connected to the hub 3 via ethernet. The amplifi router provides the LAN and mesh for whole house wifi.
