  • 170
  • 16
UnHappyBunny999
Up to speed
Message 1 of 19
Vivid 100 upload speed - 150KB/s when backing up to cloud ...
As per title really.
Speedtest tells me I'm rocking a 4.5MB/s upload speed, but the fastest I seem to be able to get with the machine plugged directly into the superhub is around 150-170KB/s
The provider (IDrive) are in the US, but reckon their kit is able to handle fearsome speeds and that any speed issue is my end.
The machines disks can pump out 30MB/s, and its only running the backup at the moment.
Just wondered if anyone had any tips, or it this could be some sort of weird throttling issue ?
I have over 1TB to backup which will take over a week at this rate !!!
  • 12.98K
  • 993
  • 2.98K
Message 2 of 19
Re: Vivid 100 upload speed - 150KB/s when backing up to cloud ...
machine plugged into hub you say - is that with the hub in modem mode - if not just do a test like that
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
  • 1.04K
  • 48
  • 91
Moderator
Moderator
Message 3 of 19
Hi UnHappyBunny999,
Very sorry to hear you have had these issues.
Are you still having trouble with this since your post?
Have you tried @-tony- great suggestion to test your connection?
If you still need any further help from us, please let us know and we will be more than happy to help.
Lindsey_C
  • 170
  • 16
UnHappyBunny999
Up to speed
Message 4 of 19
Screenshot_2019-03-11 Super Hub GUI-DS.pngScreenshot_2019-03-11 Super Hub GUI-USB.pngScreenshot_2019-03-11 Super Hub GUI-US.png
As suggested/requested.
Upload is still running (at 78% now ...) Gawd alone knows how long the next machine will take 🙂
  • 2.75K
  • 139
  • 388
jpeg1
Trouble shooter
Message 5 of 19
Just to be clear, speedtest.net measures Mb/s, not MB/s.
Is your upload arrangement measuring bits or bytes?
  • 132
  • 10
  • 28
Tsar
Superfast
Message 6 of 19
Back up a reasonable sized file to a different cloud service.
If you get a substantially different result you'll know where the issue is.
  • 4.48K
  • 304
  • 750
Roger_Gooner
Community elder
Message 7 of 19
Downstream power levels are too high, upstream a tad higher than ideal. A VM technician should have a look at this.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 170
  • 16
UnHappyBunny999
Up to speed
Message 8 of 19
KB/s ....
  • 2.75K
  • 139
  • 388
jpeg1
Trouble shooter
Message 9 of 19
@UnHappyBunny999 wrote:
KB/s ....
So your 150 KB/s is actually 1.2Mb/s. Still a lot less than the 4.5Mb/s that speedtest tells you, but not as bad as your title suggests.
You know that the VM modem and circuit is capable of 4.5 Mb/s uplink and you should be able to get that speed.  I think you need to investigate locally why you can't get that much data into the Hub from your PC.
Is the backup PC performing compression and de-duplication on your files? That could explain the lower speed.
  • 2.24K
  • 140
  • 567
cje85
Problem sorter
Message 10 of 19
Upstream is showing 39 or 40 which should be fine as the limit is 50+. Downstream needs lowering though.
