  • 16
clarkycal
Message 41 of 55
Re: Virgin Media routing issues AGAIN
Happening again? Around 3am to 3:45am
  • 15.16K
  • 510
  • 1.85K
Forum Team (Retired) Jen_A
Message 42 of 55
Hi Sigma and all others on this thread,
To be honest we're not sure exactly what's happening here, as the issue appears to be non-CMTS specific. We've complied all the data relating to those affected and this is now under investigation. Interesting that some of you mention that VPN access is fine - are you able to browse via IP when the issues occur? I know that won't be possible with gaming servers but am thinking of those of you who report problems navigating to this Forum?
Keep us updated and we'll get back to you as and when we have any progress to report.
Many thanks for your patience in the meantime Smiley Happy
Jen
  • 15
Dharcsu
Message 43 of 55
Not sure if I also fall into this issue but I can use certain sites like youtube, things like WoW and steam are unresponsive, don't have a VPN to test if that helps, but just adding to the count of people affected Smiley Sad
Internet was just unusable for 30 minutes before posting this.
  • 15.16K
  • 510
  • 1.85K
Message 44 of 55
Thanks Dharcsu, had already included you after searching for other threads/posts on this subject Smiley Happy
Jen
  • 265
  • 15
matt-h
Dialled in
Message 45 of 55
Just wanted to throw my hat into the ring as I seem to be having issues though for me , in M33 , I seem to have issues with the autotrader website etc. Sometimes I can get on and things look fine and then I can get on but different bits won't load ie car images etc.
Tried a trace route via network utility and it times out at step 4 and 7
Traceroute has started…
traceroute to www.autrotrader.co.uk (103.224.182.238), 64 hops max, 72 byte packets
 1  routerlogin.net (192.168.0.1)  2.366 ms  1.311 ms  1.246 ms
 2  10.11.148.1 (10.11.148.1)  10.500 ms  9.405 ms  17.391 ms
 3  bagu-core-2b-xe-221-0.network.virginmedia.net (62.252.244.37)  11.279 ms  8.598 ms  8.088 ms
 4  * * *
 5  * * *
 6  86.85-254-62.static.virginmediabusiness.co.uk (62.254.85.86)  20.229 ms  20.186 ms  17.980 ms
 7  213.46.174.46 (213.46.174.46)  19.241 ms  16.802 ms  18.709 ms
 8  be2868.ccr41.lon13.atlas.cogentco.com (154.54.57.153)  17.792 ms  21.632 ms  24.524 ms
 9  be2317.ccr41.jfk02.atlas.cogentco.com (154.54.30.185)  232.038 ms  113.553 ms  4056.980 ms
10  * be2806.ccr41.dca01.atlas.cogentco.com (154.54.40.106)  1159.869 ms  109.474 ms
11  be2112.ccr41.atl01.atlas.cogentco.com (154.54.7.158)  145.985 ms  161.871 ms  205.005 ms
12  be2687.ccr41.iah01.atlas.cogentco.com (154.54.28.70)  205.022 ms  176.583 ms  204.269 ms
13  be2927.ccr21.elp01.atlas.cogentco.com (154.54.29.222)  204.718 ms  175.716 ms  204.794 ms
14  be2929.ccr31.phx01.atlas.cogentco.com (154.54.42.65)  204.627 ms  277.376 ms  204.739 ms
15  be2940.rcr51.san01.atlas.cogentco.com (154.54.6.121)  205.349 ms  276.387 ms  204.808 ms
16  te0-0-2-3.nr11.b022887-0.san01.atlas.cogentco.com (154.24.7.230)  204.769 ms  260.741 ms  205.442 ms
17  38.140.111.58 (38.140.111.58)  204.777 ms  276.270 ms  204.098 ms
18  sw02-ae0-san.trellian.com (103.224.213.238)  205.445 ms  204.464 ms  204.941 ms
19  lb-182-238.above.com (103.224.182.238)  204.067 ms  205.069 ms  204.874 ms
Same issue when route google.co.uk even though can access it ok.  Seems to affect wired and wireless although headline speeds etc are ok.
Spoke to the offshore support who wasn't much help and then said would escalate to the network team but then passed me to gadget support who asked why they'd done that and then when I was put back they cut me off.
Be nice to find out whats going on as even uptown lunchtime and just after everything was fine.
this is google.co.uk
traceroute to www.google.co.uk (172.217.23.163), 64 hops max, 72 byte packets
 1  routerlogin.net (192.168.0.1)  1.854 ms  1.377 ms  1.362 ms
 2  10.11.148.1 (10.11.148.1)  8.764 ms  12.651 ms  14.224 ms
 3  bagu-core-2b-xe-221-0.network.virginmedia.net (62.252.244.37)  8.508 ms  10.251 ms  20.265 ms
 4  * * *
 5  tele-ic-8-ae5-0.network.virginmedia.net (62.252.224.94)  17.270 ms  15.285 ms  16.152 ms
 6  86-14-250-212.static.virginm.net (212.250.14.86)  17.547 ms  17.626 ms  17.610 ms
 7  * * *
 8  108.170.232.104 (108.170.232.104)  28.722 ms  20.703 ms  27.615 ms
 9  108.170.246.175 (108.170.246.175)  17.655 ms  14.616 ms  18.354 ms
10  216.239.57.227 (216.239.57.227)  18.662 ms  16.032 ms  17.888 ms
11  108.170.234.118 (108.170.234.118)  20.881 ms  33.689 ms  21.595 ms
12  108.170.234.11 (108.170.234.11)  27.271 ms  39.821 ms  26.526 ms
13  72.14.239.166 (72.14.239.166)  28.837 ms  31.072 ms  30.299 ms
14  108.170.252.1 (108.170.252.1)  32.290 ms  29.102 ms  29.975 ms
15  216.239.47.247 (216.239.47.247)  33.768 ms  28.389 ms  27.706 ms
16  fra15s22-in-f163.1e100.net (172.217.23.163)  36.943 ms  29.561 ms  30.109 ms
Every affected site ive seen all time out at hops 4 and 7
  • 265
  • 15
matt-h
Dialled in
Message 46 of 55
Another one with Routing issues here... seem to get it when trying to access auto trader and google and probably others. Can get on them but on autotrader sometimes images load and the they don't.
When I traceroute autotrader I get this...
 traceroute to uk.cache.tradermedia.net (193.243.130.87), 64 hops max, 72 byte packets
 1  routerlogin.net (192.168.0.1)  1.823 ms  1.449 ms  1.209 ms
 2  10.11.148.1 (10.11.148.1)  11.310 ms  8.307 ms  10.485 ms
 3  bagu-core-2b-xe-221-0.network.virginmedia.net (62.252.244.37)  11.674 ms  10.400 ms  23.029 ms
 4  * * *
 5  * * *
 6  m674-mp2.cvx1-b.lis.dial.ntli.net (62.254.42.162)  19.657 ms  22.555 ms  20.628 ms
 7  * * *
 8  * * *
 9  uk-lon01b-rb2-ae0-0.aorta.net (84.116.140.218)  24.363 ms  26.067 ms  22.688 ms
10  213.46.174.134 (213.46.174.134)  30.364 ms  29.305 ms  32.548 ms
11  213.46.174.134 (213.46.174.134)  31.774 ms !X * *
12  * * *
13  * 213.46.174.134 (213.46.174.134)  29.988 ms !X
This was where I stopped the recent test. Looks like its okay till it hits the main network?
  • 265
  • 15
matt-h
Dialled in
Message 47 of 55
Sorry for extra post but just tried browsing to the site and all seems okay so it seems hit and miss...annoying
  • 15.16K
  • 510
  • 1.85K
Message 48 of 55
Hi all,
Just for clarity:
This thread is specific to issues accessing certain sites/games between 12am and 3:30am. Any issues experienced outside of those times would be best posted on a new thread so that they can be investigated individually.
For those affected by the aforementioned problem - Networks are requesting an update - has the problem resurfaced since last Sunday?
Many thanks,
Jen
b2311e
Message 49 of 55
No, I haven't seen this happen so far this week
  • 18
  • 6
ItsSushi
Message 50 of 55
Not had this since. If you guys changed something my packet loss seemed to be down last night too at the cost of my ping being unstable and higher by like 20-30 to the game I was playing.
