  • 5
Chris34731
Message 1 of 7
Very very slow broadband speed - area 20
Had my broadband in for about 3 weeks and installed it myself (used to be an engineer for virgin media everything was still present and a mate of mine gave me the hub to do it myself) first 2 weeks it's been fine. Over the last 5 days it's been absolutely terrible down to 15mb and drop outs on my son's Xbox which is hard wired to the hub. My misses moan's Instagram runs slow and half the stuff won't load soon as she turns off WiFi and goes 4G it works straight away so this isn't an Instagram issue.
Downstream levels where high and upstream too low but have since been altered with a wideband attentuator but the problem is still there and the brosdband is running crap never had any issues like this with my sky fibre
  • 5
Chris34731
Message 2 of 7
Re: Very very slow broadband speed - area 20
  • 8.66K
  • 888
  • 1.35K
Message 3 of 7
Sorry, but if you are an ex-VM engineer and you cant fix it yourself, then you need to call it in as a fault and get a VM employee to check it out at their end for you.
  • 33
mdbray66
Message 4 of 7
i'm in area 20 and have just upgraded from 200 to 350. can you guess on which day i upgraded??
  • 5
Chris34731
Message 5 of 7
So I take it someone from Virgin doesn't want to reply to this ?
  • 2.75K
  • 139
  • 388
jpeg1
Trouble shooter
Message 6 of 7
They will eventually, but if you want it attended to promptly you'd be better off phoning it in as advised.
  • 653
  • 33
  • 45
Message 7 of 7
Hello Chris34731
Sorry to hear of the broadband issues but thank you for posting this on the forum. Are the speeds effected over a wired connection also? We have these WiFi tips  virg.in/wifihelp available to help boost the signal strength and range.
Over the last 5 days have you called and spoken to the technical team to get this looked into further? If so, what have they advised?
Rob
