Pjain
Very slow speed every day same time
Hello, for last few months, every day  between 4.30 and 6pm, my internet (Fibre 100) really goes down very slow. It happens on all the devises, even on laptop directly connected through Ethernet.
looking at other similar posts, I have created a live My BQM link
can someone pls help!
Tags (3)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Very slow speed every day same time
Which Hub do you have ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you please
Pjain
Hi Mike, I have hub3 and I posted BQM link as edit to original post. Thanks
