on 27-03-2020 07:21
For the past week my download and upload speeds have fluctuated hugely. My upload during the day is very slow, anywhere between 0.2Mbps and 1.2Mbps. I'm trying to work from home and the upload is dropping conference calls etc and making it very difficult to work. This is both on wired and wireless connections, I've complete a hard reset of the router etc. I used the help messaging and the only response I got (after 24 hours) was to hard reset the router which I'd already done. No further replies.
I've called VM 4 times, disconnected after 30+ minutes 3 times and finally got through to someone. They told me I had received a speed upgrade and to complete another hard reset of my router. I did say that I was dubious that this would resolve the issue but completed nonetheless. Still the same issues during the day. It's fine first thing this morning but I know that come 9am it will slow to a crawl again.
Is this a backend capacity issue within VM or a localised issue? I'm in the Cambridge area.
Answered! Go to Answer
on 05-04-2021 10:51
Hi @MatthewBest.
Thanks for your post 🙂
I'm sorry to see you're experiencing slow speeds, I can appreciate this must be frustrating and we apologise for any inconvenience caused.
I've managed to locate your account, and I can see there is a local network performance issue causing slow and intermittent speeds affecting your service currently. Could you please check the coax cable is connected securely to the Hub?
on 05-04-2021 21:59
on 06-04-2021 11:45
Hi Matthew,
Thank you for coming back to us, glad to hear your upload is looking more where it should be, please let us know if you have any further issues?
Paul.
on 09-04-2021 10:25
We are also in the N7 area of London and have had the same problem for a week. Very frustrating... we are home working and so it has been a real issue for us.
Same as the problems above, running checks and resets including hard resets do not fix the problem. I’ve checked all cables multiple times.
Calling VM the automated message has said “this problem will be fixed by 14:10” but this message hasn’t changed for several days. I am concerned by the fact this has taken other users in this thread a month to be fixed.
Is there still work on the network? If so, is it possible to get a realistic update as to when this might be fixed? And also a refund for the loss of service over the past week?
Any help or advice would be greatly appreciated. Many thanks.
on 09-04-2021 11:27
All you can do is keep complaining on this Forum.
Mine is now averaging 15Mbs Upload now.
on 10-04-2021 10:18
Hi, this is still a problem for us as per my post above. It’s been a week now.
VM please help us.
on 10-04-2021 23:59
Also in N7 and experiencing the exact same issue.
Originally the problem was that my WiFi kept dropping, split into 2.4 and 5 and still no luck. Gave up and connected via ethernet. The internet is stable now but upload speed is less than 1MB.
Can someone from VM please look into this with urgency?
on 11-04-2021 00:02
on 11-04-2021 17:30
Here is today’s Speedtest.
We would be very grateful if this could be fixed ASAP please
on 12-04-2021 13:35
Hi ll606,
Thanks for posting and welcome to our community 🙂
I'm very sorry to see you're having some connection issues, the BQM doesn't look great.
I've been able to locate your account using your forum details, and can see there are some SNR issues flagging up.
I've raised an outage for this, this type of issue is typically resolved within 5-7 days.
Alex_Rm
