on 27-03-2020 07:21
For the past week my download and upload speeds have fluctuated hugely. My upload during the day is very slow, anywhere between 0.2Mbps and 1.2Mbps. I'm trying to work from home and the upload is dropping conference calls etc and making it very difficult to work. This is both on wired and wireless connections, I've complete a hard reset of the router etc. I used the help messaging and the only response I got (after 24 hours) was to hard reset the router which I'd already done. No further replies.
I've called VM 4 times, disconnected after 30+ minutes 3 times and finally got through to someone. They told me I had received a speed upgrade and to complete another hard reset of my router. I did say that I was dubious that this would resolve the issue but completed nonetheless. Still the same issues during the day. It's fine first thing this morning but I know that come 9am it will slow to a crawl again.
Is this a backend capacity issue within VM or a localised issue? I'm in the Cambridge area.
Answered! Go to Answer
on 29-04-2020 09:26
An engineer has checked and my power levels are still wrong despite the previous tech visit 3-4 weeks ago. I've got another tech coming out on Friday who will also fix my landline (hopefully!).
Thanks for you reply!
on 04-05-2020 17:02
So the engineer that was supposed to come out on Friday was cancelled. This was because the visit was raised against the issue I was having with my landline, this was resolved centrally as part of a wider issue. My visit was automatically cancelled by the system.
One of the forum team confirmed my power levels are still out last week but now I can't get hold of them to make me a new engineer appointment. Could someone from the forum team contact me to arrange another engineer visit?
Latest router status below:
1 323000000 7 35 256 qam 24
2 139000000 6.6 35 256 qam 1
3 147000000 6.6 35 256 qam 2
4 155000000 6.6 35 256 qam 3
5 163000000 6.5 35 256 qam 4
6 171000000 6.3 35 256 qam 5
7 179000000 6 35 256 qam 6
8 187000000 5.8 34 256 qam 7
9 195000000 5.3 35 256 qam 8
10 203000000 4.6 34 256 qam 9
11 211000000 4 34 256 qam 10
12 219000000 3.5 34 256 qam 11
13 227000000 2.7 33 256 qam 12
14 235000000 1.7 33 256 qam 13
15 243000000 0.4 33 256 qam 14
16 251000000 1.2 33 256 qam 15
17 259000000 2.5 33 256 qam 16
18 267000000 3.5 34 256 qam 17
19 275000000 4.3 34 256 qam 18
20 283000000 4.6 34 256 qam 19
21 291000000 5 35 256 qam 20
22 299000000 5.5 35 256 qam 21
23 307000000 6 35 256 qam 22
24 315000000 6.4 35 256 qam 23
1 Locked 35.7 85395 0
2 Locked 35 28145 0
3 Locked 35 41693 0
4 Locked 35 21051 0
5 Locked 35.5 18085 0
6 Locked 35.5 16587 0
7 Locked 35 31236 0
8 Locked 34.9 59456 0
9 Locked 35 79896 0
10 Locked 34.4 169105 0
11 Locked 34.4 230852 0
12 Locked 34.3 482977 0
13 Locked 33.9 1513744 0
14 Locked 33.8 2236572 0
15 Locked 33.4 4673961 0
16 Locked 33.8 4384485 0
17 Locked 33.9 1987833 0
18 Locked 34.4 648447 0
19 Locked 34.9 269060 0
20 Locked 34.9 135310 0
21 Locked 35 95654 0
22 Locked 35 118029 0
23 Locked 35.5 86108 0
24 Locked 35.5 81052 0
1 46199946 5.1 5120 64 qam 1
2 39399980 5.075 5120 64 qam 2
3 32599875 5.1 5120 64 qam 3
4 25799957 5.1 5120 64 qam 4
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
03/05/2020 13:35:45 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 02:07:14 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 17:18:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 14:38:46 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 02:27:17 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 02:27:17 Warning! B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 02:21:17 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 02:18:55 critical No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 02:18:51 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 02:18:46 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 02:17:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 01:04:26 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 01:02:17 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 01:02:12 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 01:02:12 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2020 19:27:15 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2020 18:47:38 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2020 18:47:32 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2020 18:47:32 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 28-01-2021 12:34
Hi All,
I can't upload or join my team meetings. My MS Team meetings are usually dropped and can't talk online. I have recently moved to Virgin M500 deal to enjoy high speed but my upload speed is driving me crazy and disrupts my job a lot.!!! My download is fine and around 200mbs but my upload is around 0.3 mbs. It is not even 1mb. This morning, I had to use my hotspot to upload a doc. Can you please look at the network status below and tell me what I need to do. I am in N14 area.
1 | 32599650 | 47 | 5120 | 16 qam | 11 |
2 | 46200053 | 47.3 | 5120 | 16 qam | 9 |
3 | 39399873 | 47 | 5120 | 16 qam | 10 |
4 | 25799976 | 46.8 | 5120 | 16 qam | 12 |
1 | ATDMA | 0 | 0 | 3 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 6 | 0 |
on 29-01-2021 20:03
Hi Keith,
I've seen you give some great help to people on these forums, I was wondering if it would be possible to do the same for me?
I'll give you a quick rundown if that's okay.
I used to be on the 200M package with Virgin Media and for a long time it was perfectly fine. 20Mbps upload worked when I streamed, uploaded files, etc. About a few months after the pandemic, my upload speed took hits for months which affected my hobbies and job. I was offered a free upgrade to the 300M after countless phonecalls and complaints. I was told that the upgraded package to the 300M one would solve my issue because I would have "more upload to work with" during peak hours. For a while this was true but once again, my upload can go from 36Mbps+ so single digits and it is again affecing my livelihood.
I am going to complain again but I urgnetly need some kind of fix outside of VM just admitting they have absolutely awful traffic management.
Kind Regards,
Dan
on 30-01-2021 16:41
on 12-02-2021 13:47
And another one. ON the MB200 package, upload speeds used to be 20MB on the dot, but now, fluctuates between 1MB and 2.5MB.
Tried every setting imaginable, from firmware uploads on PC, router, tweaking network settings (Ethernet), but something's changed and also unable to get any useful support.
01-03-2021 13:12 - edited 01-03-2021 13:17
And another here in HP6.
My slow speed is to the minute, 0900-1900. Either side of those times, I see ~20Mbps. Between 0900 and 1900 I get 1-3Mbps.
Yet, Virgin Media are adamant they're not traffic shaping at all. 🙄
I can run a speed test at 08.59 and get 20Mbps, then at 09.01 it'll hit the floor at 1-3Mbps.
https://twitter.com/adamlstr/status/1361995687148290050 My twitter exchange with Virgin Media is a similar 'bang head against wall' type of interaction.
on 02-03-2021 11:44
Hello adamlstr
Thanks for your post
Apologies for the poor service
Can you please set up a BQM and leave it for the next 48 hours
Post the results in here and we can have a look at what is happening
Gareth_L
on 02-03-2021 14:53
BQM's appear to only monitor latency by measuring ping response.
My ping is unaffected during these times, it remains 11-15ms.
My upstream speed between the hours of 0900 and 1900 drops from 20Mbps to 2Mbps. It's appalling.
on 03-03-2021 10:41
Hi adamlstr
Would you like me tro arrange an engineers visit then to check things over
Gareth_L
