javidm
  • 6
Message 1 of 5
Variable speeds with low SNR and high errors
Dear Team
I am on a 350 Mbps package and my speeds vary greatly between low 20s and high 90s most of the time, occasionally going upto 200 and very occasionally above 200. The speed can vary considerably on consecutive speed tests. I have tested the speeds with a Cat 5e ethernet cable connected directly between the Hub and a gigabit network card with no other devices connected at the main entry point of the property to exclude internal wiring problems and wifi or congestion issues. I dont have any problems personally with the service for browsing and watching videos however the gamers in the household are complaining bitterly of lag and slow speeds.
The Hub status logs suggests a problem on Channels 4 and 5 with reduced SNR and high error counts. The log also gives very frequent error messages which are copied below.
An engineer has been round once and he mentioned that 2 channels were "red" and the others were "green" and there were no problems at the property and that he raised an issue with broadband support who would investigate further. The following day the online service status did show a problem in the area and that an engineer was on his way and that problem is now resolved but my issues remains the same.
I have copied and pasted sections of the network status pages highlighting the issues.
Channel Frequency (Hz) Power  SNR  Modulation Channel ID
1             331000000         2.4       40          256 qam 25
2             203000000         2.5       40          256 qam 9
3             211000000         2.7       40          256 qam 10
4             219000000         2.5       31          256 qam 11
5             227000000         2          33          256 qam 12
6             235000000         2.5       40          256 qam 13
7             243000000         1.4       40          256 qam 14
8             251000000         2          40          256 qam 15
1                  Locked            40.3                 404             14
2                  Locked            40.3                 231             1
3                  Locked            40.3                 106             13
4                  Locked            31.2                 5440405     3710390
5                  Locked            33.5                 1579768     335122
6                  Locked            40.3                  96              13
7                  Locked            40.3                  91               0
8                  Locked            40.9                  94               0
02/06/2020 19:09:6 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 19:09:5 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 19:05:57 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 19:05:56 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 19:04:2 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 19:04:1 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 19:01:38 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I would very grateful for your assistance.
M Javid
Eeeps
  • 757
  • 47
  • 119
Rising star
Message 2 of 5
Re: Variable speeds with low SNR and high errors
Hopefully you can get the noise problems resolved quickly. It would be worth posting your upstream levels too.
Are you using a SH2 on a 350Mb/s package? Since this only bonds 8 downstream channels the maximum rate is only 400Mb/s
You should really be using a SH3.
javidm
  • 6
Message 3 of 5
Apologies, I am on SH3 I just had not scrolled down the tables far enough. My upload speeds tend to be quite good at around 30 Mbps which is sometimes higher than my download speeds. Full tables posted below:
Thanks again for your help
5             227000000                      2.2        33            256 qam 12
6             235000000                      2.7        40            256 qam 13
7             243000000                      1.5        40            256 qam 14
9             259000000                      1.4        38            256 qam 16
10           267000000                      1.5        38            256 qam 17
11           275000000                      1.9        40            256 qam 18
12           283000000                       2          40            256 qam 19
13           291000000                       2.2       40            256 qam 20
14           299000000                       3          40            256 qam 21
15           307000000                       2.5       40            256 qam 22
16           315000000                       3          40            256 qam 23
17           323000000                       3.2       40            256 qam 24
18           339000000                       3.2       40            256 qam 26
19           347000000                       2.7       40            256 qam 27
20           355000000                       2.7       40            256 qam 28
21           363000000                       3.2       40            256 qam 29
22           371000000                       2.9       40            256 qam 30
23           379000000                       2.9       40            256 qam 31
24           387000000                       3          40            256 qam 32
1 Locked                                    40.3                2462 110
2 Locked                                    40.3              34846 320
3 Locked                                    40.3              21962 233
4 Locked                                    31.1        99424847 70566739
5 Locked                                    33.9          5005101 803120
6 Locked                                    40.3              54755 846
7 Locked                                    40.3              18058 175
8 Locked                                    40.3              13665 161
9 Locked                                    38.9              10716 260
10 Locked                                  38.9              10960 225
11 Locked                                  40.3                8610 191
12 Locked                                  40.9                6864 162
13 Locked                                  40.3                4518 164
14 Locked                                  40.3                2486 145
15 Locked                                  40.3                 2279 99
16 Locked                                  40.3                 2128 167
17 Locked                                  40.3                 2018 107
18 Locked                                  40.3                 1388 134
19 Locked                                  40.9                  2110 85
20 Locked                                  40.3                 1748 118
21 Locked                                  40.9                 1215 185
22 Locked                                  40.3                 2370 73
23 Locked                                  40.3                 1120 2158
24 Locked                                  40.9                   449 76
1 46200014                                4.85                       5120              64 qam 1
2 25800000                                4.625                     5120              64 qam 4
3 32600000                                4.65                       5120              64 qam 3
4 39400024                                4.725                     5120              64 qam 2
1 ATDMA                            0                   0                   0                   0
2 ATDMA                            0                   0                   0                   0
3 ATDMA                            0                   0                   0                   0
4 ATDMA                            0                   0                   0                   0
javidm
  • 6
Message 4 of 5
Apologies, I am on SH3 but I had not scrolled all the way down when copying the tables. I have copied and pasted the full tables below. The SNR seems to have dropped further and channel 4 is no longer locked. My upload speeds are quite satisfactory and sometimes even higher than my downloads speeds ! The upload table does not seem to be showing any problems.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
1.7
40
256 qam
25
2
203000000
1.7
40
256 qam
9
3
211000000
1.9
38
256 qam
10
4
219000000
1.5
24
256 qam
11
5
227000000
1.5
32
256 qam
12
6
235000000
1.7
40
256 qam
13
7
243000000
0.5
38
256 qam
14
8
251000000
1
38
256 qam
15
9
259000000
0.4
38
256 qam
16
10
267000000
0.7
38
256 qam
17
11
275000000
0.9
40
256 qam
18
12
283000000
1
40
256 qam
19
13
291000000
1.2
40
256 qam
20
14
299000000
2
40
256 qam
21
15
307000000
1.5
40
256 qam
22
16
315000000
2.2
40
256 qam
23
17
323000000
2.2
40
256 qam
24
18
339000000
2.4
40
256 qam
26
19
347000000
1.7
40
256 qam
27
20
355000000
2
38
256 qam
28
21
363000000
2.4
40
256 qam
29
22
371000000
2
40
256 qam
30
23
379000000
2
40
256 qam
31
24
387000000
2
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
2462
110
2
Locked
40.3
34846
320
3
Locked
40.3
21962
233
4
NotLocked
31.1
99424847
70566739
5
Locked
33.9
5005101
803120
6
Locked
40.3
54755
846
7
Locked
40.3
18058
175
8
Locked
40.3
13665
161
9
Locked
38.9
10716
260
10
Locked
38.9
10960
225
11
Locked
40.3
8610
191
12
Locked
40.9
6864
162
13
Locked
40.3
4518
164
14
Locked
40.3
2486
145
15
Locked
40.3
2279
99
16
Locked
40.3
2128
167
17
Locked
40.3
2018
107
18
Locked
40.3
1388
134
19
Locked
40.9
2110
85
20
Locked
40.3
1748
118
21
Locked
40.9
1215
185
22
Locked
40.3
2370
73
23
Locked
40.3
1120
2158
24
Locked
40.9
449
76
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200014
4.85
5120
64 qam
1
2
25800000
4.625
5120
64 qam
4
3
32600000
4.65
5120
64 qam
3
4
39400024
4.725
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Emily_G
  • 4.78K
  • 207
  • 285
Message 5 of 5
Thank you for the post Javidm.
I'll pop you over a private message so we can look into the account to see what's going on for you.
Please respond to this by going to the purple envelope in the top right of your screen.
Thank you, Emily.
