Telfo1991
  • 6
Message 1 of 5
VM350M - extremely low upload
We're experiencing extremely low upload speeds, numerous different speedtests all return result below 1Mbps.
Have tried rebooting hub3 (modem mode) and router (ac86u) numerous times to no avail. Called the 0345 and was on hold for 40 minutes before the call dropped.
Will post logs
Tags (1)
Telfo1991
  • 6
Message 2 of 5
Re: VM350M - extremely low upload
1298750000440256 qam21
21387500005.140256 qam1
3146750000540256 qam2
41547500004.840256 qam3
51627500004.840256 qam4
61707500004.840256 qam5
71787500004.540256 qam6
81867500004.640256 qam7
91947500004.540256 qam8
102027500004.540256 qam9
112107500004.540256 qam10
122187500004.540256 qam11
132267500004.440256 qam12
142347500004.340256 qam13
152427500004.540256 qam14
162507500004.540256 qam15
172587500004.540256 qam16
182667500004.640256 qam17
192747500004.440256 qam18
202827500004.543256 qam19
212907500004.540256 qam20
22306750000440256 qam22
23314750000440256 qam23
24322750000440256 qam24
1Locked40.950
2Locked40.3322
3Locked40.950
4Locked40.960
5Locked40.940
6Locked40.350
7Locked40.940
8Locked40.940
9Locked40.350
10Locked40.950
11Locked40.950
12Locked40.950
13Locked40.950
14Locked40.940
15Locked40.350
16Locked40.950
17Locked40.370
18Locked40.950
19Locked40.950
20Locked43.360
21Locked40.950
22Locked40.970
23Locked40.960
24Locked40.960
Telfo1991
  • 6
Message 3 of 5
1 39400039 45 5120 64 qam 2
2 25800000 43.2 5120 16 qam 4
3 32600000 43.7 5120 16 qam 3
4 46200017 45 5120 64 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Telfo1991
  • 6
Message 4 of 5
09/12/2020 19:28:34 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 19:28:20 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 17:10:35 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 06:46:27 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 06:46:27 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 00:20:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/12/2020 11:05:51 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/12/2020 11:05:51 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2020 06:41:53 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 23:05:51 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 23:05:51 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2020 21:51:59 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/11/2020 11:05:51 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/11/2020 11:05:51 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 15:09:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 23:05:51 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 23:05:51 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 11:20:4 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 11:05:51 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 11:05:51 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Two of your Upstream Channels are running at 16 QAM, all four channels should be at 64 QAM.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
