jimnageotte
VIVID200 Broadband Speed
What's reasonable to expect from the VIVID200 broadband service? I ran speedtests with my computer connected to the router via ethernet cable ten times. Also, I ran the troubleshooting utility that's on the Virgin Media website (it showed no problems). Using speedtest.com, the best download speeds I got were 81mbps, and the best upload were 11.7mbps. Is that really the best this service can provide? Or is it safe to assume this is worth having Virgin Media check out? Thanks.
  • 291
  • 8
  • 22
StormW4tch3r
Superfast
Re: VIVID200 Broadband Speed
Your device is probably limiting you, does it say how fast you are connected via ethernet status? also post downstream/upstream stats.
jimnageotte
Thank you. I don't understand what you mean by "does it say how fast you are connected via ethernet status." The speedtest results I mentioned were from running the test via an ethernet connection (cable direct from my computer to the Verizon broadband router).
  • 965
  • 137
  • 418
Andruser
Well-informed
Verizon broadband router?  I hope you mean Virgin Media broadband router?
Assuming you meant Virgin Media, it is very unlikely that a PC or Mac (or Linux) computer would be limiting your speed on an ethernet connection.  I'm on 200, and routinely get speeds that measure over 220 (a moment ago, fairly peak time of a Sunday afternoon, and it was 223).  Use the default speedtest server - that'll usually be a Virgin Media test server, which is how it should be (your testing your connection, not the onward hops to servers on other networks.
At 81 Mbps sounds like you've got a connection problem.  If you connect to your router, don't log in, but view the router status pages, paste them in this thread (nothing showing your IP address though) and somebody who knows about such things will be able to advise.  You may also want to set up a bradband quality montior over at thingkbroadband.com as that will show if you've got any problems with latency of dropped packets.
  • 7.28K
  • 759
  • 1.14K
Legend
Aren't they using Verizon Hubs in Eire ?
IT could be limiting if its an old PC with an old (non-Gigabit) network card,
Agree tho', it is probably a connection issue although a 10/100 network card would max out around 80mbps - so it's intriguing that's the number he gets.
OP: can you check and post the network card in your PC?
jimnageotte
Thanks. Yes, I meant a Virgin Media router (Hub 3.0). Here are the router status pages:
Cable Modem Status
Item
Status
Comments
251000000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
251000000
8
36
256 qam
11
2
323000000
8.9
36
256 qam
20
3
315000000
8.8
37
256 qam
19
4
307000000
8.8
36
256 qam
18
5
299000000
8.9
36
256 qam
17
6
291000000
8.5
36
256 qam
16
7
283000000
8.6
37
256 qam
15
8
275000000
8.6
37
256 qam
14
9
267000000
8.8
36
256 qam
13
10
259000000
8.5
36
256 qam
12
11
243000000
7.5
36
256 qam
10
12
235000000
7
36
256 qam
9
13
227000000
7
35
256 qam
8
14
219000000
7.1
35
256 qam
7
15
211000000
7.5
36
256 qam
6
16
203000000
8
36
256 qam
5
17
195000000
8.4
36
256 qam
4
18
187000000
8.8
36
256 qam
3
19
179000000
8.9
36
256 qam
2
20
171000000
9
36
256 qam
1
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
36.3
94
0
2
Locked
36.6
48
0
3
Locked
37.3
49
0
4
Locked
36.6
50
0
5
Locked
36.6
45
0
6
Locked
36.6
33
0
7
Locked
37.3
23
0
8
Locked
37.6
30
0
9
Locked
36.6
31
0
10
Locked
36.6
40
0
11
Locked
36.3
127
0
12
Locked
36.3
157
0
13
Locked
35.7
338
0
14
Locked
35.7
454
0
15
Locked
36.3
180
0
16
Locked
36.3
146
0
17
Locked
36.3
35
0
18
Locked
36.6
55
0
19
Locked
36.6
36
0
20
Locked
36.3
89
29
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
39
5120
64 qam
3
2
25800000
39
5120
32 qam
4
3
39400000
39.8
5120
64 qam
2
4
46200000
40.3
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
2
0
4
ATDMA
0
0
2
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
9834ncxv9873254k;fg8
SFID
382
Max Traffic Rate
220000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
381
Max Traffic Rate
12700000
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Time
Priority
Description
2018-09-25 00:07:43.00
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Warning!
critical
2018-09-25 00:07:49.00
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-25 00:08:00.00
Warning!
2018-09-25 00:08:01.00
critical
Warning!
critical
2018-09-25 00:08:05.00
Warning!
2018-09-26 23:14:10.00
critical
