on 24-01-2022 20:07
I pay for gig 1 fibre And I’m ment to be getting at least 50mbps upload speed and im only getting 10 on a wired connection, my download speed is almost perfect running at 980 mbps it’s just the upload I’m not happy with, any ways round this.
on 24-01-2022 20:55
on 25-01-2022 14:17
Post your power levels and network log from the Hub. Include the Pre and PostRS errors. Also setup a BQM here www.thinkbroadband.com/ping
In the meantime try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
