  • 3.28K
  • 103
  • 366
VMCopperUser
Problem sorter
Message 31 of 34
Re: Upload speed
I think the problem is when the timer for the site starts later than the upload does.  So you get this strange situation where if it thinks it starts by the time half the data has been sent then your speed looks twice as high as it should.  I have seen this before, but only on connections where people had software issues!
I do not work for VM, but I would. It is just a Job.
I would also make websites for them, because the job never seems to require the website to work.
  • 24.6K
  • 1.02K
  • 3.84K
Message 32 of 34
Re: Upload speed
21mbps on the top package.
VM wont upgrade the uplaod speed until most of the UK suppliers can match it. Why would they
  • 3.44K
  • 44
  • 735
Ignition
Wise owl
Message 33 of 34
Re: Upload speed
Same reason they increase the download way in advance of most of the competition.
Could have been higher a while ago but not such a big issue here. Should see movement soon though.
  • 378
  • 18
  • 45
happywithmy350
Fibre optic
Message 34 of 34
Re: Upload speed
Good Good - waiting for it Smiley Happy
