DeanPeoples
Upload speed unstable
Hi all, I am having issues recently regarding my upload speed which does not seem to be consistent at all. I am currently on the vivid 350 package. The download speed always seems to be holding steady however the upload is always fluctuating and ranging anywhere between 6-13mb. I have done all I can but I seem to be getting no where. I will upload screenshots of the info from the router which is being used in modem mode however to rule it out I also changed to original setup just to be sure.
Any suggestions would be helpful.
  • 12.34K
  • 937
  • 2.73K
Re: Upload speed unstable
upstream levels could be the the problem - depends what your connection is - if you are on RFOG (radio frequency over glass) then they could be ok - if you are one the more common - read older setup then they are low
____________________
Tony
  • 52
Hi there.
Thank you for visiting Community
Sorry to hear about the upload unstable speed you are getting.
Please let us know, is your connection wired or wireless?
If problem persist please drop us both wired and wireless results from speedtest.net, from differing times of the day if possible, and we can follow things up for you.
Please let us know how it goes.
^elvee_o
