  • 5
Adam1998
Message 1 of 10
Upload speed unstable
I have the virgin 350 vivid package which just got installed in my house 2 weeks ago.
Since then i have had unreliable and unstable upload speeds.Downloads speeds are totally fine
Tried phoning multiple times and spoke to multiple mangers who either cold transfered or hung up on the call.
Would like to get this sorted as I rely heavliy on my upload speed and cant seem to figure out the problem.
I have my full network on brand new cat6 cables and tried with one device connected but still have the same issues.
Really not happy with this service as im paying over £100 a month to virgin and seem to be getting no help at all
  • 11.75K
  • 779
  • 3.46K
Message 2 of 10
Re: Upload speed unstable
Some metrics would be good- you got speed-tests or similair showing the issue?
Where are you uploading to? Whats happening with the speed?
Click to learn more about VIP
Use Kudos to say thanks
  • 5
Adam1998
Message 3 of 10
here is the results of from the speed test we have ran over the past 24 hours, what you are seeing in the upload has been the same since day 1download.pngupload.png
We are streaming to twitch
  • 9.13K
  • 947
  • 1.43K
Message 4 of 10
worth posting up your Hub/network connection details and someone will check to see if there is a problem there.  Go to http://192.168.0.1  (or http://192.168.100.1  - if in modem mode) in your browser [there is no need to login] and then click on the  “router status” text at bottom middle of first page up and then copy/paste 3 sets of data onto here - the downstream, upstream , &  network logs.  Don't worry about the formatting it can be easily read (by others & not by me!), but try and avoid using screen shots & don’t include personal data or mac addresses.
  • 11.75K
  • 779
  • 3.46K
Message 5 of 10
Are you using a single threaded or multithreaded test for upload?
  • 5
Adam1998
Message 6 of 10
Channel Frequency (Hz) Power (dBmV) SNR (dB)  Modulation  Channel ID
1          323000000      -2         38        256 qam          24
2          315000000      -2         40        256 qam          23
3          307000000      -2         38        256 qam          22
4          235000000      -1.2      40        256 qam          13
5          227000000      -0.9      40        256 qam          12
6          219000000      -0.7      40        256 qam          11
7          211000000      -0.4      40        256 qam          10
8          203000000      -0.4      40        256 qam          9
9          195000000      -0.2      40        256 qam          8
10        187000000      0          40        256 qam          7
11        179000000      0          40        256 qam          6
12        171000000      0.2       40        256 qam          5
13        163000000      0.4       40        256 qam          4
14        155000000      0.4       40        256 qam          3
15        147000000      0.5       40        256 qam          2
16        139000000      0.4       40        256 qam          1
17        299000000      -2         38        256 qam          21
18        291000000      -2         38        256 qam          20
19        283000000      -2         40        256 qam          19
20        275000000      -1.7      40        256 qam          18
21        267000000      -1.7      40        256 qam          17
22        259000000      -1.5      40        256 qam          16
23        251000000      -1.5      40        256 qam          15
24        243000000      -1.2      40        256 qam          14
1          Locked 38.6     18        0
2          Locked 40.3     20        0
3          Locked 38.9     29        0
4          Locked 40.3     18        0
5          Locked 40.3     10        0
6          Locked 40.3     6          0
7          Locked 40.9     7          0
8          Locked 40.9     8          0
9          Locked 40.3     26        0
10        Locked 40.3     14        0
11        Locked 40.9     7          0
12        Locked 40.3     14        0
13        Locked 40.3     20        0
14        Locked 40.3     23        0
15        Locked 40.9     11        0
16        Locked 40.9     6          0
17        Locked 38.6     20        0
18        Locked 38.9     15        0
19        Locked 40.3     13        0
20        Locked 40.3     6          0
21        Locked 40.3     12        0
22        Locked 40.3     10        0
23        Locked 40.3     8          0
24        Locked 40.3     14        0
1          39400000        30.5     5120    64 qam            2
2          25800000        30        5120    64 qam            4
3          32600000        30        5120    64 qam            3
4          46200000        30.5     5120    64 qam            1
Channel           Channel Type  T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
1          ATDMA            0          0          0          0
2          ATDMA            0          0          6          0
3          ATDMA            0          0          0          0
4          ATDMA            0          0          13        0
Time    Priority Description
1970-01-01 00:01:21.00         Error    Missing Mandatory MDD TLV on primary DS Channel
1970-01-01 00:01:35.00         critical No Ranging Response received - T3 time-out
1970-01-01 00:02:42.00         critical DHCP FAILED - Discover sent, no offer received
1970-01-01 00:01:22.00         Error    Missing Mandatory MDD TLV on primary DS Channel
1970-01-01 00:01:37.00         critical No Ranging Response received - T3 time-out
2018-11-17 13:10:57.00         Error    DHCP RENEW sent - No response for IPv4
2018-11-17 13:21:46.00         Error    DHCP REBIND WARNING - Field invalid in response
2018-11-17 13:21:46.00         notice  DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified
2018-11-17 17:23:19.00         critical No Ranging Response received - T3 time-out
2018-11-22 11:41:54.00         Error    DHCP RENEW sent - No response for IPv4
2018-11-23 06:09:47.00         critical No Ranging Response received - T3 time-out
2018-11-23 10:34:40.00         Error    DHCP RENEW sent - No response for IPv4
2018-11-23 18:12:22.00         Error    DHCP REBIND WARNING - Field invalid in response
2018-11-23 18:12:22.00         notice  DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified
2018-11-23 22:42:53.00         critical No Ranging Response received - T3 time-out
2018-11-25 17:44:26.00         notice  SW Download INIT - Via Config file
2018-11-25 17:46:59.00         notice  SW download Successful - Via Config file
2018-11-26 12:47:05.00         critical No Ranging Response received - T3 time-out
2018-11-26 20:01:11.00         critical TLV-11 - Failed to set duplicate elements
2018-11-28 14:45:43.00         critical No Ranging Response received - T3 time-out
  • 5
Adam1998
Message 7 of 10
We have been using speedtest.net for testing speeds
  • 9.13K
  • 947
  • 1.43K
Message 8 of 10
Upstream power levels are a little out of spec..  (Upstream: no lower than 31dBmV and no higher than 50dBmV --- 44dBmV - 46dBmV is optimal)  Others will comment on the significance.
  • 5
Adam1998
Message 9 of 10
how can we fix that?
  • 9.13K
  • 947
  • 1.43K
Message 10 of 10
Need a technicians visit - if its "significant".
