Danzilla0411
Upload speed slow
In the last week or so my upload has been around 0.30, usually it is around 20. I have followed the more basic help tips like checking cables, testing speed via ethernet device and have now also done a full factory reset but the upload is still painfully slow. It is affecting my ability to work from home so hoping I can get some help on here as I cannot get in touch with Virgin through the usual methods, I expect it is a busy time. I have copied my router status info below as I have seen this done in other threads. If anyone can shine a light on potential fix I would really appreciate it. Thanks!
443000000
Locked
Ranged Upstream Channel (Hz)
32599993
Locked
Provisioning State
Online Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14430000002.440256 qam29
22190000002.240256 qam11
32270000002.240256 qam12
42350000002.240256 qam13
52430000001.740256 qam14
62510000001.940256 qam15
72590000002.440256 qam16
82670000002.540256 qam17
92750000002.740256 qam18
10283000000340256 qam19
11291000000340256 qam20
12299000000340256 qam21
133070000002.740256 qam22
143150000002.940256 qam23
15323000000340256 qam24
164110000002.740256 qam25
174190000002.540256 qam26
184270000002.740256 qam27
194350000002.540256 qam28
204510000001.740256 qam30
214590000001.240256 qam31
224670000001.240256 qam32
234750000001.440256 qam33
244830000001.540256 qam34
1Locked40.921061134
2Locked40.3310429000
3Locked40.3375026793
4Locked40.3399122533
5Locked40.3436015985
6Locked40.3360620298
7Locked40.3372221745
8Locked40.3381621058
9Locked40.3378319701
10Locked40.3408215837
11Locked40.3414512084
12Locked40.9401215449
13Locked40.9406316662
14Locked40.9375116005
15Locked40.3346714027
16Locked40.3379214875
17Locked40.9313518053
18Locked40.9271814248
19Locked40.924295580
20Locked40.331314415
21Locked40.333926795
22Locked40.334008391
23Locked40.927299623
24Locked40.324838009
1325999934.125512064 qam11
2258000004512064 qam12
3393999884.125512064 qam10
4461999984.125512064 qam9
3ATDMA0000
4ATDMA0000
Danzilla0411
Re: Upload speed slow
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
UBsgvca69834ncxv9873254k;fg87d
SFID25363
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID26662
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
29/03/2020 00:22:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 23:36:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 23:36:22Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 17:28:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 01:37:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 01:36:58criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 01:34:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 01:34:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 22:35:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 11:41:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 20:31:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 20:22:29noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 20:19:42noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 08:13:42noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 08:13:42ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 01:16:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/03/2020 23:43:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/03/2020 18:20:2ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/03/2020 14:47:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/03/2020 04:26:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
