Upgraded to 1Gig - less stable than M600 before?
WhiteHartMart
Not sure if I have issues with my connection but upgraded to 1Gig a week or so back but it's just not as consistent/stable as the 600mb plan I had before.
Had the SH3 in modem mode to a Negear Orbi system before and now have the SH4 connected in the same way.
I seem to get regular loss of connection for a split second or so every day around 5pm as I lose connection to some work based systems which need a constant connection.  Occasionally, family members have issues with basic tasks (web browsing etc) and my BQM seems to have significant latency spikes - my 600 connection had been pretty stable in recent months.
Wondered if someone can take a look please - thinking I might just cancel and move back to a slower but more consistent connection else.
BQM
3.0 Downstream channels
14110000003.79999938.983261QAM2561
24190000003.40000238.605377QAM2562
34270000003.50000038.983261QAM2563
44350000003.40000240.366287QAM2564
54430000003.50000040.366287QAM2565
64510000003.29999938.605377QAM2566
74590000003.09999838.983261QAM2567
84670000003.20000140.366287QAM2568
94750000003.40000238.983261QAM2569
104830000003.70000138.983261QAM25610
114910000003.79999940.366287QAM25611
124990000003.90000240.366287QAM25612
135070000003.79999940.366287QAM25613
145150000003.90000238.605377QAM25614
155230000004.09999838.983261QAM25615
165310000004.19999740.366287QAM25616
175390000004.19999740.366287QAM25617
185470000004.30000338.983261QAM25618
195550000004.30000338.983261QAM25619
205630000004.30000340.366287QAM25620
215710000004.30000340.366287QAM25621
225790000004.19999738.983261QAM25622
235870000004.19999738.983261QAM25623
245950000004.09999840.366287QAM25624
256030000004.09999838.605377QAM25625
266110000004.40000238.983261QAM25626
276190000004.30000340.366287QAM25627
286270000004.30000338.983261QAM25628
296350000004.09999840.366287QAM25629
306430000004.19999740.366287QAM25630
316510000004.19999740.366287QAM25631
1Locked38.98326100
2Locked38.60537700
3Locked38.98326100
4Locked40.36628700
5Locked40.36628700
6Locked38.60537700
7Locked38.98326100
8Locked40.36628700
9Locked38.98326110
10Locked38.98326170
11Locked40.36628710
12Locked40.36628710
13Locked40.36628710
14Locked38.60537700
15Locked38.98326100
16Locked40.36628700
17Locked40.36628700
18Locked38.98326100
19Locked38.98326100
20Locked40.36628700
21Locked40.36628700
22Locked38.98326100
23Locked38.98326100
24Locked40.36628700
25Locked38.60537700
26Locked38.98326100
27Locked40.36628700
28Locked38.98326110
29Locked40.36628700
30Locked40.36628700
31Locked40.36628700
38 REPLIES 38
Hi Cardiffman281,
Thank you for reaching out to us in our community and welcome back, there has been an issue reported with the BQM, which is being investigated, once we have some more information we will add an update Via our community.
Paul.
I guess these issues still aren't resolved nationally??
In addition to the latency issues, still getting a number of times per day where I lose connection momentarily - only seconds or so then it's ok again.
Also - how long do Virgin Media take to respond to lodged complaints - I have a reference number from about a month ago with no reply yet - does the regulator not have a standard response time that has to be met?
My Broadband Ping - Orbi Mesh 1Gig
Hi WhiteHartMart,
Thank you for reaching back out, sorry to see you are still seeing some disconnections, AI have had another look our end and cannot see any current issues, I cannot run further checks due to you having a 3rd party Router, I will be happy to check further however you would need to put our Router back into Router mode, once done please let us know.
Paul.
Thanks - I ran it in router mode for a short while and changed back when it made absolutely zero difference (plus I lost the wifi range I needed in the house as the SH4 wasn't up to scratch in that dept). Changed back to modem mode once I'd eradicated my router as the issue.  Don't really have to change everything back another time - will have to see how things are once the national issues are fully resolved.
Thank you for the response @WhiteHartMart.
I have had a look at our systems and I can confirm there are no area issues on the system. I have however identified an issue with your downstream power levels. I have sent you a private message to further look into this. Please lookout for the purple envelope and provide a response when you can.
Akua_A
Akua_A
No problem at all @WhiteHartMart
Please do let us know how the appointment goes and if you need any further help.
Akua_A
Hi @WhiteHartMart.
I am glad to hear your power levels are under control since the appointment.
Please do not send public messages unless invited to do by our team. This would allow all our team to be able to best help if individual members of the team are away.
However, in this one instance, I can take a further look into your Channel 4  issue. I have had a look at our system and everything seems in order in regards to your service. Just to clarify, how are you accessing channel four? Does this also occur with other channels?
Akua_A
Just looking at my modem stats?  Its dropped to 16 QAM now on channel 4.
3.0 Upstream channels
14620000043.2705995120 KSym/sec64QAM3
26030000043.7705995120 KSym/sec64QAM1
35370000043.7705995120 KSym/sec64QAM2
43940000043.0205995120 KSym/sec16QAM4
