02-10-2021 10:47 - edited 02-10-2021 10:52
I upgraded to the M500 package last week and since then I've been getting speeds around 250 max which is what I was getting before the upgrade.
I've tried ethernet and wifi, with me getting even lower speeds when hardwired.
I'm using the superhub 3 which has been hard reset and still no improvement.
on 02-10-2021 11:03
Acquired Downstream Channel (Hz) | 195000000 | Locked |
Ranged Upstream Channel (Hz) | 53700009 | Locked |
Provisioning State | Online |
1 | 195000000 | 6.1 | 38 | 256 qam | 8 |
2 | 139000000 | 5.9 | 40 | 256 qam | 1 |
3 | 147000000 | 5.9 | 40 | 256 qam | 2 |
4 | 155000000 | 6 | 40 | 256 qam | 3 |
5 | 163000000 | 5.9 | 40 | 256 qam | 4 |
6 | 171000000 | 6 | 38 | 256 qam | 5 |
7 | 179000000 | 6 | 38 | 256 qam | 6 |
8 | 187000000 | 6.3 | 38 | 256 qam | 7 |
9 | 203000000 | 6 | 40 | 256 qam | 9 |
10 | 211000000 | 6 | 39 | 256 qam | 10 |
11 | 219000000 | 6 | 40 | 256 qam | 11 |
12 | 227000000 | 6 | 40 | 256 qam | 12 |
13 | 235000000 | 5.8 | 40 | 256 qam | 13 |
14 | 243000000 | 5.6 | 40 | 256 qam | 14 |
15 | 251000000 | 5.6 | 40 | 256 qam | 15 |
16 | 259000000 | 5.3 | 40 | 256 qam | 16 |
17 | 267000000 | 5.1 | 40 | 256 qam | 17 |
18 | 275000000 | 5 | 40 | 256 qam | 18 |
19 | 283000000 | 5 | 40 | 256 qam | 19 |
20 | 291000000 | 5 | 40 | 256 qam | 20 |
21 | 299000000 | 5.3 | 38 | 256 qam | 21 |
22 | 307000000 | 5.5 | 40 | 256 qam | 22 |
23 | 315000000 | 5.5 | 40 | 256 qam | 23 |
24 | 323000000 | 5.6 | 40 | 256 qam | 24 |
1 | Locked | 38.9 | 9 | 0 |
2 | Locked | 40.3 | 9 | 0 |
3 | Locked | 40.3 | 8 | 0 |
4 | Locked | 40.9 | 5 | 0 |
5 | Locked | 40.3 | 6 | 0 |
6 | Locked | 38.9 | 8 | 0 |
7 | Locked | 38.9 | 9 | 0 |
8 | Locked | 38.6 | 23 | 0 |
9 | Locked | 40.3 | 8 | 0 |
10 | Locked | 39.8 | 8 | 0 |
11 | Locked | 40.3 | 11 | 0 |
12 | Locked | 40.3 | 21 | 0 |
13 | Locked | 40.3 | 19 | 0 |
14 | Locked | 40.3 | 9 | 0 |
15 | Locked | 40.3 | 11 | 0 |
16 | Locked | 40.3 | 11 | 0 |
17 | Locked | 40.3 | 10 | 0 |
18 | Locked | 40.3 | 7 | 0 |
19 | Locked | 40.9 | 10 | 0 |
20 | Locked | 40.3 | 12 | 0 |
21 | Locked | 38.9 | 20 | 0 |
22 | Locked | 40.3 | 11 | 0 |
23 | Locked | 40.9 | 10 | 0 |
24 | Locked | 40.3 | 7 | 0 |
1 | 53700009 | 29 | 5120 | 64 qam | 2 |
2 | 39400000 | 29.3 | 5120 | 64 qam | 4 |
3 | 46199991 | 29.3 | 5120 | 64 qam | 3 |
4 | 60300039 | 29.3 | 5120 | 64 qam | 1 |
on 02-10-2021 11:04
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
SFID | 9680 |
Max Traffic Rate | 575000000 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 9677 |
Max Traffic Rate | 38520000 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
02/10/2021 10:09:7 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/10/2021 10:08:52 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 21:54:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 17:00:3 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 16:45:58 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 19:18:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/09/2021 23:29:27 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/09/2021 23:29:27 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/09/2021 14:05:1 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/09/2021 22:54:13 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/09/2021 22:54:12 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/09/2021 19:54:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/09/2021 10:54:13 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/09/2021 10:54:13 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/09/2021 07:58:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/09/2021 23:11:53 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/09/2021 23:11:53 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/09/2021 13:09:51 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/09/2021 09:36:43 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/09/2021 09:36:43 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 02-10-2021 12:58
You are provisioned for 500 okay. However your Upstream power is too low, should be between 34 to 51. VM will next to fix this.
on 04-10-2021 13:10
Hi mr_chad,
Thanks for posting and welcome to our community 🙂
I'm sorry to hear you've had some issues with your connection.
I've been able to locate your account using your forum information and can see you've been able to speak to someone regarding this.
If you do still need help with anything please let us know.
Alex_Rm
