on 21-01-2022 11:46
Hi, I upgraded my 600mbps to the 1gb service yesterday, and Virgin told me I will need a new Hub which is being sent on Monday.
My speeds have always been over 600Mbps and very stable, but since I upgraded my Speeds are just under 100Mbps?
Is this because I have the superhub3 and its not compatible with the new service or is this another issue that anyone's experienced or has heard of before?
21-01-2022 16:40 - edited 21-01-2022 16:42
Yes the 1GB service requires a Hub4 to deliver higher speeds.
Note that's only achievable on an ethernet cable connection - wifi will max out at ~600Mbps as the Hub4 is only wifi5. You will need wifi6 wireless equipment to get higher over wifi
You could try a pinhole reset of the Hub3 to see if that boosts it up to near 600. Or perhaps the ethernet cablee has failed or NIC card has reset to 100mbps
on 23-01-2022 16:51
Hi @sku11meister,
Thank you for your post and welcome back to our community forums. We're here to help.
I am very sorry to hear that you're having some slower than expected connection speeds recently. If the new router is yet to arrive, I'd recommend carrying our a wired Speed Test to get a better idea of what speeds are reaching your router.
If you're also having speed problems on a wired connection, perform a factory reset of the router and then check to see if that has helped to improve things for you.
Let us know how you get on either way.
on 29-01-2022 11:50
Hi, Thankyou for the replies. I received my hub4 and installed it, promptly put it into modem mode after letting it set itself up. Everything is working fine now, speeds are just hovering around 900mbps and upload is around the 52mbps mark. must have been my old sh3 saying goodbye 😄
