  • 6
ChrisOnfire180
Upgraded 2 weeks ago
I recently went from vívid 100 to vivid 200 but I'm still only getting speeds of 110mbps on speedtest.net
I've tried all the usual resetting of my router and I'm using cat6 ethernet to plug my laptop directly to the router to run the test.
Any ideas?
  • 12.86K
  • 975
  • 2.95K
Re: Upgraded 2 weeks ago
check the network card in your laptop - is it gigabit - if its 10/100 then you will only get around 100
even if it is gigabit check its settings to make sure its set to that
____________________
Tony
