Escott64
  • 8
Message 1 of 15
Upgrade not working
Good afternoon,
I recently upgraded my internet from 100mbs to 350mbs. I received an email saying the upgrade will take place on the 31 May it is now the 2nd of June and when I check my internet speed it is 120mbs max (checked it a few times) on speed test. I have tried restarting it on Hub settings but it’s still 120mbs after. It also tells me on the virgin media app that my broadband contract is now 350mps which used to be 100mps. Is there something I am missing here?
kind regards
E
jhuk
  • 2.99K
  • 52
  • 286
Problem sorter
Message 2 of 15
Re: Upgrade not working
Either your device does not have a 1000Mb/s LAN Port or your Config File has not changed yet
Post your HUB's Config file here.
jhuk
  • 2.99K
  • 52
  • 286
Problem sorter
Message 3 of 15
Either your device does not have a 1000Mb/s Lan port of your HUB has not got the new Config File yet.
Copy/Paste it here.
Escott64
  • 8
Message 4 of 15
Config file
cmreg-vmdg505-rtsxxl35016u-b.cm
is this the right file?
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 5 of 15
Post the entirety of the configuration tab
Escott64
  • 8
Message 6 of 15
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID21174
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID21173
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 7 of 15
That’s the correct config for the 350Mbps connection.
jhuk
  • 2.99K
  • 52
  • 286
Problem sorter
Message 8 of 15
As above, it is the 350Mb/s Config (my post did not show the other day due to a flood protection warning but then I typed it a second time and both appeared).
Post a screenshot of your PC's (I assume it is a PC) Network Adapter from the Windows Network Connection section.
Escott64
  • 8
Message 9 of 15
I will have a look ASAP
I checked the internet speed all day yesterday, my average is about 100-120, but at one point in the afternoon it did manage to reach 220mbps. (Still not the 360  average it talks about, or even 350!)
this morning it is 88mbps.
The average uploads speed is now 36mbps which is definitely way better that before the upgrade (10mbps)
Escott64
  • 8
Message 10 of 15
Also I forgot to mention I have a Mac book pro, I cannot see anything about speed under network settings?
