sitotty
Up and Down Speed Matching
Hello,
My Broadband installation has just been completed, I was informed that I can get the upload speed to match the download speed, as I am a key worker and working from home and reliant on my internet connection.
Can anyone advise how I can get this done and weather it is free of charge as the installation engineer described?
Thanks in advance
Simon
Anonymous
Not applicable
Re: Up and Down Speed Matching
@sitotty wrote:
Hello,
Thanks in advance
Simon
You can't.
jem101
  • 1.71K
  • 236
  • 799
Indeed it simply isn't possible, the installer either doe...
Indeed it simply isn't possible, the installer either doesn't understand the technology he's dealing with, or simply lied!
Anonymous
Not applicable
Re: Indeed it simply isn't possible, the installer either doe...
sure its possible.
Cap you download speed to match the upload. Then they will match 😛
But really you can't/ The upload is a set maximum it can't be changed
