on 25-06-2022 07:36
Hi All,
I upgraded from the 350 package to the 1gig package yesterday. Installation went fine but the speeds i'm getting are quite erratic.
Yesterday i was able to test with the Sam Knows speed test, the average result was between 300 and 500, with the speed to the computer hitting 945 consistently so this doesn't seem to be an issue with the device i'm using to connect to the router.
I'm using the Hub 4 in router mode, hard wired via Ethernet.
Currently the speeds are hitting from anywhere as low as 100 and as high as 700 but it's really inconsistent.
I've hard reset the router multiple times, each time producing roughly the same result. Below is a screenshot of my latest test. I have also tried connecting via Wi-Fi and using my Pixel 6, speed over Wi-fi is equally as erratic.
I can see that the new package has been applied as my max traffic rate is set to 1230000450
on 25-06-2022 07:40
Downstream Readings:
25 | 331000000 | 0.599998 | 40.946209 | QAM256 | 25 |
1 | 139000000 | 2.200001 | 40.366287 | QAM256 | 1 |
2 | 147000000 | 2.000000 | 40.946209 | QAM256 | 2 |
3 | 155000000 | 1.900002 | 40.946209 | QAM256 | 3 |
4 | 163000000 | 1.599998 | 40.366287 | QAM256 | 4 |
5 | 171000000 | 1.200001 | 40.366287 | QAM256 | 5 |
6 | 179000000 | 1.000000 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 1.000000 | 40.946209 | QAM256 | 7 |
8 | 195000000 | 1.000000 | 40.366287 | QAM256 | 8 |
9 | 203000000 | 0.900002 | 40.366287 | QAM256 | 9 |
10 | 211000000 | 0.900002 | 40.366287 | QAM256 | 10 |
11 | 219000000 | 0.900002 | 40.946209 | QAM256 | 11 |
12 | 227000000 | 0.799999 | 40.366287 | QAM256 | 12 |
13 | 235000000 | 0.900002 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 1.000000 | 40.366287 | QAM256 | 14 |
15 | 251000000 | 1.099998 | 40.946209 | QAM256 | 15 |
16 | 259000000 | 1.099998 | 40.366287 | QAM256 | 16 |
17 | 267000000 | 1.200001 | 40.366287 | QAM256 | 17 |
18 | 275000000 | 1.000000 | 40.946209 | QAM256 | 18 |
19 | 283000000 | 0.700001 | 40.946209 | QAM256 | 19 |
20 | 291000000 | 0.900002 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 2.000000 | 40.946209 | QAM256 | 21 |
22 | 307000000 | 1.799999 | 40.366287 | QAM256 | 22 |
23 | 315000000 | 1.200001 | 40.946209 | QAM256 | 23 |
24 | 323000000 | 0.799999 | 40.946209 | QAM256 | 24 |
26 | 339000000 | 1.000000 | 40.946209 | QAM256 | 26 |
27 | 347000000 | 1.099998 | 40.366287 | QAM256 | 27 |
28 | 355000000 | 1.000000 | 40.366287 | QAM256 | 28 |
29 | 363000000 | 1.099998 | 40.366287 | QAM256 | 29 |
30 | 371000000 | 1.200001 | 40.366287 | QAM256 | 30 |
31 | 379000000 | 1.099998 | 40.946209 | QAM256 | 31 |
25 | Locked | 40.946209 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.946209 | 0 | 0 |
3 | Locked | 40.946209 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.946209 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.946209 | 0 | 0 |
19 | Locked | 40.946209 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.946209 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.946209 | 0 | 0 |
24 | Locked | 40.946209 | 0 | 0 |
26 | Locked | 40.946209 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.946209 | 0 | 0 |
33 | 96 | 4K | 1880 | QAM4096 | 759 |
33 | Locked | 41 | -5.5 | 77490740 | 4591 |
25-06-2022 10:05 - edited 25-06-2022 10:06
@Delmaros wrote:Downstream Readings:
3.1 Downstream channels
33 96 4K 1880 QAM4096 759 3.1 Downstream channels
33 Locked 41 -5.5 77490740 4591
Your DOCSIS 3.1 channel appears to be low on power, however still, just, in spec (-6 to +10dBmV) , however having 'Uncorrectables' is unusual.
How's the upstream?
on 26-06-2022 16:23
1 | 32600000 | 52.270599 | 5120 KSym/sec | 64QAM | 10 |
2 | 39400000 | 51.270599 | 5120 KSym/sec | 64QAM | 9 |
3 | 46200000 | 50.520599 | 5120 KSym/sec | 64QAM | 8 |
4 | 53700000 | 50.020599 | 5120 KSym/sec | 64QAM | 7 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 27-06-2022 19:35
@Delmaros wrote:Below are the upstream readings. What's the usual process for getting "Uncorrectables" rectified? Thanks for taking a look.
3.0 Upstream channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1 32600000 52.270599 5120 KSym/sec 64QAM 10 2 39400000 51.270599 5120 KSym/sec 64QAM 9 3 46200000 50.520599 5120 KSym/sec 64QAM 8 4 53700000 50.020599 5120 KSym/sec 64QAM 7
1 US_TYPE_STDMA 0 0 1 0 2 US_TYPE_STDMA 0 0 0 0 3 US_TYPE_STDMA 0 0 0 0 4 US_TYPE_STDMA 0 0 0 0
Your upstream power levels are very high, which might not be helping the downstream.
You need VM to investigate further, probably with an engineer visit to adjust the power levels at the cabinet.
on 28-06-2022 08:19
Perfect, logged a call with Virgin this morning who have escalated it to the level 2 team, just got to wait for the call back. Thanks for your help so far.
