on 27-09-2021 14:58
I have the M100 package with landline. The speed here is typically 30Mbps so only 30% of its rated speed. We lose internet completely 3 or 4 times a week. To be clear this isn't WiFi related as rebooting the hub 3 makes no difference or of it does the broadband will work for 20mins or so before failing again. I run the hub in modem mode and use a third party router.
I contacted VM about the slow speeds and unreliable service. The connection was put under investigation by OFCOM and it was verified that the speeds were poor. It was explained that VM could do nothing about it and I could have a £5 discount. I actually wanted it fixed!! Speaking to neighbours they have had similar experiences and have all moved to different suppliers.l
This has now moved on and we have intermittently been losing the dialing tone on our home phone.
Please fix it!
on 28-09-2021 15:16
on 30-09-2021 16:24
Hi Fishman81,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue with your broadband and now landline.
In regards to the landline issue, can you confirm if you have been able to try a new handset on the line? Or try your existing handset on someone else's line?
Also how intermittent is the drop of dialing tone?
^Martin
