Cjc1706
  • 58
Under half speed of 100mb line - wired computer
Hello,
Over the last week or so, my connection has only been reaching around 40-45mb of a 100mb line. I've rebooted the superhub multiple times, but the issue hasn't sorted itself. All tests have been performed on a hard wired computer, and also verified on an additional hard wired computer and other devices to rule out and issue with one particular device.
I've also done the self diagnostic test on the virgin media site which didn't find any issues, and have done multiple speed tests throughout the day.
My superhub levels are as follows, does any of it look like it could be causing an issue?:
From looking at the network logs, I'm getting a number of error messages saying either "RCS Partial Service" or "Lost MDD Timeout".
13310000000.240256 qam25
22030000000.540256 qam9
32110000000.440256 qam10
4227000000036256 qam12
5235000000040256 qam13
6243000000-0.240256 qam14
7251000000-0.240256 qam15
8259000000-0.440256 qam16
9267000000-0.540256 qam17
10275000000-140256 qam18
11283000000-140256 qam19
12291000000-0.940256 qam20
132990000000.438256 qam21
143070000001.740256 qam22
153150000001.540256 qam23
163230000000.740256 qam24
17339000000040256 qam26
18347000000040256 qam27
19355000000-0.540256 qam28
20363000000-0.740256 qam29
21371000000-1.240256 qam30
22379000000-1.738256 qam31
23387000000-1.740256 qam32
242190000000.224256 qam11
1Locked40.36213
2Locked40.332635
3Locked40.329317
4Locked36.633881179
5Locked40.324214
6Locked40.921614
7Locked40.921626
8Locked40.320814
9Locked40.926220
10Locked40.335626
11Locked40.328222
12Locked40.929124
13Locked38.913716
14Locked40.37014
15Locked40.96813
16Locked40.33510
17Locked40.37413
18Locked40.3561
19Locked40.38013
20Locked40.310213
21Locked40.35911
22Locked38.94714
23Locked40.35414
24Locked40.96213
12580000046512064 qam4
23260003447512064 qam3
33940010747512064 qam2
44619996945.5512064 qam1
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Under half speed of 100mb line - wired computer
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Copy and paste the contents of the Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish.
Cjc1706
  • 58
Config tab:
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
KDHSUBsgvca69834ncxv98732
SFID30302
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID30301
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Network Log tab:
Network LogTime Priority Description
30/12/2020 14:31:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:31:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:31:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:31:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:31:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:31:3Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:30:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:30:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:29:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:29:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:29:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:29:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:29:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:29:19Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:26:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:26:55Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:26:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:26:33Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:26:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 14:26:25Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
