13-09-2021 19:07 - edited 13-09-2021 19:17
I am a long time customer of Virgin Media since 2016 at my current address, currently on the 350mb package. The neighbouring flat have started using Virgin Media and we are now sharing a single COAX cable. The install date was 30/08 in the early afternoon and you can see from the BQM graphs having a second connection has severly affected our service. The connection was so bad in the late morning and early afternoon that around 3pm on 31/08 I went out and traced my cable, which was now loose in the device that splits the COAX cable from the street into the two connections. There were also a lot of errors in the hub/router logs, which I have attached below. Once I tightened the cable connection the frequency of the errors reduced, however we are still seeing worse service on the BQM graph than before we started sharing the COAX line. This includes still seeing a higher rate of errors in the logs.
Please could you check the line stats? See attachments below for details.
I have attached images that show:
30th August (Install day)
31st August (Install day +1)
27th August (Previous Friday for reference)
Older logs saved before they were lost 30th and 31st August
31/08/2021 13:20:33 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 11:26:18 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 11:26:5 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 11:20:49 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 11:18:53 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 11:13:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 11:13:36 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 10:57:48 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 10:57:28 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 09:56:4 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 09:55:5 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 09:49:3 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 09:45:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 09:45:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 23:25:19 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 23:25:18 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 23:15:42 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 23:15:41 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 23:14:34 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2021 23:14:12 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Newer Logs
13/09/2021 08:18:3 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/09/2021 11:02:59 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 08:18:3 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/09/2021 07:38:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/09/2021 05:39:53 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 18-09-2021 14:57
HI DizzyIT,
I am sorry to hear you are having issues, I have located your account and can see you are currently affected by an SNR outage the ETA for this is 23 SEP 2021 14:10
Zoie
on 20-09-2021 11:34
@Zoie, does this mean an engineer is scheduled to attend our property to correct both my connection and my neighbours connection?
on 20-09-2021 11:58
on 22-09-2021 13:53
Hi @DizzyIT thanks for getting back to us.
As per the advice by @lotharmat there's a wider impacting issue sorry. I would ask that you re-contact us after the current estimated fix time and we'd be able to look into this further.
Lee
on 24-09-2021 11:46
Has the fix been implemented as the date has been passed (yesterday) when it should have happened?
on 24-09-2021 17:51
The area fault should have been posted on 0800 561 0061.
If it's reporting no issues then the fault should have been cleared.
on 27-09-2021 09:43
Hi DizzyIT, I've sent you a private message to confirm your account details so we can take a look at your connections.
Cheers,
Corey C
