Terrible broadband speed
ajc72
Hi.
I'm paying (an extortionate amount) for the Gigabyte broadband. For the last 3 or 4 days I've been getting a maximum download speed of around 50Mbps - half the speed of my upload. I've rebooted the router, checked for service outages etc, but nothing changes. This is via an ethernet cable, btw, so it is not a WIFI issue.
Can this be looked into please? I am not at all happy at paying for service I am not receiving.
Thank you.
Andrew
4 REPLIES 4
carl_pearce
Community elder
Does this site show the same slow speeds?
https://samknows.com/realspeed/
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
@ajc72 wrote:
Hi.
Andrew
Hi Andrew
Are you using a computer? Usually when download speeds on a Gig1 ethernet connection drop to less than 100 Mbps it's due to either an ethernet cable or port issue, or due to the ethernet adapter. Check that the adapter settings are set to either 1.0 Gbps Full Duplex or  2.5G.
Have you checked that the ethernet cable is snug and tight, or tried changing ports or a different ethermet cable?
Dave
David_Bn
Thanks for reaching out to us @ajc72, and welcome back to our Community Forums!
Sorry to hear of the issues with the speed of the service you're currently experienicing.
If you can please address the points that have been raised on the thread by your fellow Forum posters, we will be best placed to offer further guidance if this is required.
David_Bn
