  • 6
AnnCamilla
Message 1 of 9
SuperHub 2ac hardly connecting at all to wifi
We should be receiving 200 Mbps. Instead download is rarely above 3.71 and upload 11.90. I rang the Virgin support number, had a long conversation with India I think, and no help at all. I'm receiving emails sent before 10am this morning at 4pm this afternoon and working is so difficult under these circumstances. Wish I knew what to do. Followed all the advice on the website to no avail.
  • 9.13K
  • 946
  • 1.43K
Message 2 of 9
Re: SuperHub 2ac hardly connecting at all to wifi
You done the pinhole reset to factory settings ?
Have you checked on an ethernet cabled device to see whether that is giving full speed?
  • 6
AnnCamilla
Message 3 of 9
Thank you for your reply. Yes, the hub has been reset and rebooted, pleaded with and nurtured!! The ethernet cable worked wonders until about a week ago on my big, powerful iMac. Bought a new one two days ago, just in case. Made no difference (Cat 6 in case you're wondering).
  • 9.13K
  • 946
  • 1.43K
Message 4 of 9
Have you tried shifting to the other network -- 5GHz & 2.4GHz -- and see if will connect better on the other one?
Are you using Chrome by any chance? If so see this similar issue from an iMac user that was resolved by using Safari. Have you tried different browsers ?
https://community.virginmedia.com/t5/Speed/Etherent-speed-slow/m-p/3912102#M202773
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 5 of 9
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.0.1
Don't log in, click the Router Status button
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, but do obscure personal information like your WAN IP address.
  • 6
AnnCamilla
Message 6 of 9
Thank you all for your replies. Here are the logs:
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
435000000
411000000
419000000
427000000
443000000
451000000
459000000
467000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
4
1
2
3
5
6
7
8
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
Symbol Rate (Msym/sec)
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
-4.28
-5.34
-4.95
-4.55
-4.49
-4.52
-4.57
-4.46
RxMER (dB)
28.72
27.61
28.03
28.46
28.75
28.72
28.83
28.94
Pre RS Errors
-1289338857
-705179641
-801179435
-1070513692
-1327564714
-1373983784
-1424849418
-1604641884
Post RS Errors
89037
95172608
9495337
506015
80581
53992
52699
12086
Upstream
US-1
US-2
US-3
US-4
Channel Type
2.0
2.0
2.0
2.0
Channel ID
7
8
6
5
Frequency (Hz)
32600000
25800000
39400000
46200000
Ranging Status
Success
Success
Success
Success
Modulation
64QAM
32QAM
64QAM
32QAM
Symbol Rate (Sym/sec)
5120000
5120000
5120000
5120000
Mini-Slot Size
4
4
4
4
Power Level (dBmV)
46.50
46.50
48.00
48.50
T1 Timeouts
0
0
0
0
T2 Timeouts
0
0
0
0
T3 Timeouts
0
0
0
0
T4 Timeouts
0
0
0
0
First Time
Last Time
Priority
Error Number
Description
10/06/2019 14:04:47 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 20:29:57 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 20:18:05 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 20:13:11 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:28:47 GMT
Warning (5)
66050310
Auth Success - Web login successful.
09/06/2019 10:05:17 GMT
Error (4)
68010302
DHCP WAN IP - 82.24.252.251
09/06/2019 10:04:18 GMT
Error (4)
68000407
TOD established
Time Not Established
Notice (6)
84000510
Downstream Locked Successfully
09/06/2019 10:02:06 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:01:58 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:01:45 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:01:31 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:01:24 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:01:14 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:00:55 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:00:42 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:00:26 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 10:00:02 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 09:59:39 GMT
Warning (5)
84020200
Lost MDD Timeout
09/06/2019 09:59:27 GMT
Warning (5)
84020200
Lost MDD Timeout
  • 13.12K
  • 1K
  • 3.05K
Message 7 of 9
you have problems on the downstream - pre and post rs errors are awful as are the RxMER levels - you can check the coax connections are tight to the hub - if all is good then you need a tech to sort that - wait for VM to pick the thread up they should sort something
____________________
Tony
  • 6
AnnCamilla
Message 8 of 9
Thank you all for your help. Much appreciated. Getting on with work now.
  • 6
AnnCamilla
Message 9 of 9
It's been marginally better since my last post but still not what we're paying for. Will ring 150 again . . .
