  • 12
LPJA
Message 1 of 128
Super Hub 3 slow in modem mode
I have had my broadband upgraded to vivid 350 and the router to super hub 3, since then I have had poor speeds (something I am not used to with virgin).
If the SH3 is in router mode I am getting around 350mbps wired connection, as soon as I put it in modem mode and connect my Asus n66u the speeds drop to 120mbps.
Why???
I did not have any issues with my SH2 and this is the only thing that has changed.
I am getting quite frustrated with VM as when I spoke to there support team, they insinuated it was my home network and not there SH3.
I beg to differ!
  • 125
  • 52
Wolfclaw
Up to speed
Message 2 of 128
Re: Super Hub 3 slow in modem mode
Plug your SH directly to a PC and then do a speed test, N66 can easily handle your connection, but only if NAT Acceleration is turned on, if you have QOS enabled, this normally switches it off.
  • 12
LPJA
Message 3 of 128
I just checked NAT Acceleration and it is set to Auto.
Download speed when connected to ASUS and SH3 in modem mode.
Download Speed when connected to SH3 in router mode (I was unable to connect when in modem mode).
It's a big difference and I am now paying more, for what I thought was a premium service.....
I was on vivid 200 before and got better speeds with the SH2, Kicking myself for not keeping hold of it!
  • 12
LPJA
Message 4 of 128
I am so disappointed with VM, surely they must of tested the SH3 in modem mode before releasing them to customers.
How can they let a good service be compromised by a poor product?!?!
  • 12.75K
  • 400
  • 730
Forum Team (Retired) Heather_J
Message 5 of 128
Hello LPJA,
Thanks for posting and a big welcome to the Community 😄
Sorry that you'r getting poor speeds while using your Asus router. If the correct speeds are reaching your property, then it does suggest the issue lies with the equipment. We can see from your direct hard-wired test that 383Mb is achievable. I don't have much experience with the Asus routers, but I'll leave your thread open for other members to comment.
Speak soon,
Take care.
Heather_J
  • 12.54K
  • 480
  • 1.12K
Message 6 of 128
Have you tried a speed test with a PC connected to the modem mode port when in modem mode?
  • 12
LPJA
Message 7 of 128
I did try but my laptop wouldn’t get a connection, I’m assuming I should be using dhcp and it should connect.
I also tried disconnecting the router and addressing my laptop the same as that plugged into the modem, no connection.
Puzzled........
  • 12.54K
  • 480
  • 1.12K
Message 8 of 128
You may need to power off the hub when in modem mode for 2 mins to allow a MAC change for your laptop other then that unplug and re-plug the cable from your laptop.
  • 12
LPJA
Message 9 of 128
Well I managed to get it to assigned an IP address to my laptop and run the test in modem mode.
The fingers now pointing at my Asus N66u running Merlin 380.69.......................
  • 44
  • 10
Blueyonderer
Dialled in
Message 10 of 128
I had exactly the same problem a few weeks ago and I've concluded that modem mode on the SH3 is broken... (download speed capability is severely limited)
I get full speed (around 390Mbps) when connected to the SH3 in router mode with everything disabled and my own router running in the DMZ.
As soon as I connect in modem mode the speed falls to around 220-230Mbps despite everything else being left as-is.
This is a repeatable process.
My SH3 now runs in router mode full time and, well-known latency issues aside, it's actually been running stably in this configuration.
