  • 31
londondesigner
Message 1 of 5
Sudden Packet Loss?
Hi all,
I'm suddenly getting broadband drop outs, on closer inspection there's massive packet drops.
I'll give the customer service people a call but fear I won't get far.  Any suggestions?
  • 2.1K
  • 137
  • 528
cje85
Problem sorter
Message 2 of 5
Re: Sudden Packet Loss?
There's a bug with the Hub 3 which causes it to randomly stop responding to the ThinkBroadband graph, showing as 100% packet loss.
However if your connection was really suffering 100% packet loss it would be completely dead, and you wouldn't have any internet access at all.
The graph is a red herring in this case and best disregarded, but you might want to post your modem stats and network logs, to help determine the cause of your separate drop outs problem.
  • 31
londondesigner
Message 3 of 5
IC - so turned off the firewall on the router and Ping returned to normal.  So Red Herring!
Router however is still rebooting with no obvious pattern..
1451000000-2.540256 qam26
2171000000-0.440256 qam5
3179000000-0.740256 qam6
4187000000-0.740256 qam7
5195000000-0.740256 qam8
6203000000-0.940256 qam9
7211000000-1.240256 qam10
8219000000-1.740256 qam11
9227000000-240256 qam12
10235000000-2.240256 qam13
11243000000-2.240256 qam14
12251000000-240256 qam15
13259000000-240256 qam16
14267000000-1.740256 qam17
15275000000-240256 qam18
16283000000-1.540256 qam19
17291000000-140256 qam20
18299000000-0.540256 qam21
19307000000-0.440256 qam22
20315000000-0.740256 qam23
21323000000-0.940256 qam24
22443000000-2.940256 qam25
23459000000-2.240256 qam27
24467000000-2.440256 qam28
1Locked40.3100
2Locked40.300
3Locked40.9150
4Locked40.340
5Locked40.950
6Locked40.350
7Locked40.360
8Locked40.350
9Locked40.960
10Locked40.300
11Locked40.300
12Locked40.950
13Locked40.950
14Locked40.350
15Locked40.340
16Locked40.350
17Locked40.350
18Locked40.3210
19Locked40.350
20Locked40.360
21Locked40.3140
22Locked40.300
23Locked40.3120
24Locked40.300
1394000004.625512064 qam2
2258000004.475512064 qam4
3326000004.625512064 qam3
4462000004.625512064 qam1
3ATDMA0000
4ATDMA0000
  • 31
londondesigner
Message 4 of 5
Here's the Network Log: Time Priority Description 08/03/2019 10:02:6 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 08/03/2019 17:42:15 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 08/03/2019 17:42:15 notice DHCP Renew - lease parameters tftp file-V0dea97109ea7aa00.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 09/03/2019 13:15:15 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 11/03/2019 20:32:25 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 12/03/2019 16:57:6 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 12/03/2019 16:57:6 notice DHCP Renew - lease parameters tftp file-V0dea97109ea7aa00.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 13/03/2019 03:14:25 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 17/03/2019 04:43:8 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 17/03/2019 09:10:25 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 17/03/2019 19:24:52 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 17/03/2019 20:55:18 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 18/03/2019 02:45:44 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 18/03/2019 07:01:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 18/03/2019 08:16:23 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 18/03/2019 10:06:40 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 18/03/2019 10:06:40 notice DHCP Renew - lease parameters tftp file-V0dea97109ea7aa00.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 20/03/2019 10:15:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 01/01/1970 00:01:25 Error Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 22/03/2019 16:17:47 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 105
Message 5 of 5
Thanks for contacting community @ londondesigner
Have you spoken to our team about this?
We need to run some tests with you and investigate further.
We can do this via online chat. Let us know how it goes. ^Ellen_C
